One of the components of the MLT-13 is a Steel fishing leader (Pendulum Spring). Can anyone give me the specs on it or give me a link on which one to purchase?
Marc Tovar's MLT-13
Tags: None
I don't remember which one I used but I think it was somewhere around #12 which is .029 diameter. Anything between 12 and 19 will work you would just adjust your slot width. There is a pattern for bending it to shape do you have that?Tim
If you need a tool and don't buy it, you will pay for it and not have it -
Tim, Thanks for your response. I do have the pattern for bending it. I'm just trying to determine the gauge of the wire.Comment
Tim, I think I'm going to purchase this wire on Amazon and use the 2mm wire. let me know what you think.
304 Stainless Steel Spring Wire, 40cm Lengh Straight Steeless Steel Spring Wire Assortment Kit, Hard Steel Straight Wire Diameter 0.4mm 0.6mm 0.8mm 1mm 1.2mm 1.4mm 1.6mm 1.8mm 2mm 3mm, 100Pcs
Thanks,
by RolfOur Judges are some of the best woodworkers I have ever met. On occasion I get asked to explain what I look for in the scrolling categories. I point out all of the nuances. I can't be a judge as I have intarsia and scroll work entries.
Today, 07:36 AM -
by RolfThere may have been some crud on the tips from manufacturing.
In the ~20 years of scrolling I never cleaned the ends of my blades until recently. Even with the Pegas clamps I was having some blade slippage, I now scuff the ends of my blades with some 220 grit paper End of problem.!...-
Today, 07:29 AM -
by NC ScrollerDon’t over sand them as you will shorten their usable life. Only sand as needed. Another thing to do is clear your blades before installing. Blades are coated with oil to prevent rust. Wipe the ends with alcohol or lightly sand with 320 grit.
Today, 05:29 AM -
by cwmageeThe fact that you only had approximately 6 hours on the saw tells me there was a thin oily film on the clamps from the manufacturing process.
If problem continues you may have spread the clamps in the process of tighten blades. A common problem with OEM parts. This issue will disappear by replacing...-
Yesterday, 08:46 PM -
Reply to Mitre saw material clampsby will898910” compound dual bevel sliding mitre saw with laser. Bruce said to buy a new blade because the blade that comes with it sucks. Sells here for $289. It was on sale plus his military discount and a $50 gift certificate from his woodworking club. Bruce said to check out on Google 10” kolbalt mitre...
Yesterday, 08:45 PM -
