I would like your help
  • I would like your help
    I started this 13 years ago, put it away in a box after having bought the pattern and wood. (I could not cut it. It was before learning about using tape and the right blade) Thanks to Scott's post yesterday I woke up at 3 am thinking about what to make. I dug out my old box of wood (most still unwrapped) to make something for myself . Before I start, my first question to this group is which way should the wood grain go (in my 3/4 hardwood I like the grain going up and down). I am not sure for this as I do very little thin wood cutting.. I do know I will use some BB as a carrier for some of the delicate fretcuts. Thanks to Bob Duncan I learned a lot about cutting 1/4 wood and using a pin nailer.
    Thanks In advance Here is what I picked. (I am sure I will have more questions) going to use 1/4 Red oak and 1/8 Red oak plywood.
    The other John A. Nelson
    johnsworkshop.com
    sigpic
    As intricate as that fretwork is, as long as the grain is running the same way, I don't think there will be any visual disturbances.
    Lots of blade entries there, so I wish you steady hands and great patience.
      What did I say? Whatever it was I am truly sorry.
      Just my two cents but on small pieces like that the grain will hardly be noticeable.
        Wow, John, that is sure a wonderful piece. Dianne said that if I tried it and a little piece broke, the rest would go into the fire pit. I think I will scroll Baby Animal puzzles. LOL
        Denny
        ArtCrafters in Dayton, TN
          that is agood looking clock when its done. I built one and I had the Grain going up & down.
            If I understand you correctly you will be using red oak plywood. If it is solid red oak I would suggest some other wood. Red oak is notorious, at least in my experience to self destruct along the strong grain lines. This will be delicate no matter what solid wood you use. I like Cherry. JMO
              The 1/4 is solid.. at least this time I will know that it is not all me and can blame part of it on the wood.. My go to wood is cherry and black walnut. a few weeks ago I cut a piece in 3/4 red oak and snapped a piece..
              johnsworkshop.com
              sigpic
                That's a nice project. Looking forward to seeing yours when done.
                As for grain direction, does the pattern offer any guidance? Sometimes there are indicator lines on the pattern for each piece, showing the recommended grain direction. If not, then it's up to your best judgement. There really is no practical way to avoid narrow, delicate cross grain areas in fretwork like that, but I would tend to run the grain in the direction of the longest dimension of each piece.
