Gluing a project
  • Gluing a project
    I am gluing a project that needs to lay flat while it dries. Any ideas what I can lay it on?
    Mike
    Use a layer of wax paper on top of your work bench, or on the floor, or on top of your table saw...
      That will work, thanks.
      Mike
        I got a slab of granit counter top at our local thrift shop for $10 It is a perfect assembly area I have it on top of a rolling cabinet I built. Easy to clean and scrape old glue off.
        It is only about 2ft x 2ft.
          That's a great idea, Rolf! I'm off to visit the thrift shop.
          Jan
            That piece of granite counter top, or even a piece of granite tile, will make a great surface to lay a piece of sand paper on to sharpen a chisel or plane blade.
              My granit work station with a work in progress.
              I put a shelf on the side for my Xyron. Also notice the overhang that is to give some room to clamp stuff
                I just use a 1/4" piece of scrap plywood. I have a number of sizes for different sied projects. Cheap and when if too much glue gets on it i toss it.
                  hi rolf what is the xyron for isn't the for scrapbooking?
                  Jerry
                    The Xyron unit is for putting adhesive on to patterns. If you use the REPOSITIONABLE roll, you can run the patterns thru the unit. You can buy the unit either on the internet or use one of those 50% off coupons at Michael's, AC Moore, Hobby Lobby, or JoAnne Fabrics. When I bought mine a few years ago, it was cheaper to buy from the internet and then use those coupons (on an ongoing basis) to purchase the refill cartridges.
                    Barbara
                    Proud user of Excalibur, RBI Hawk, & Delta
                    • Sandy Oaks
                      Reply to Another Mid-Michigan Scroller
                      by Sandy Oaks
                      Welcome to the forum from TN. The bowls and basket are beautiful. Bowls are fun to make, I especially like making bowls from Carole Rothman's books.
                      Today, 03:00 PM
                    • planeur
                      Reply to The St-Nicolas sheriff
                      by planeur
                      Thanks a lot Jim for your support and advises.
                      as I said I like more and more that scrollsaw hobbies.
                      I will show you a another one soon, a creation, my first one!
                      planeur
                      Today, 02:28 PM
                    • DaveVanEss
                      U Just bought another year of Scrollmania
                      by DaveVanEss
                      I got my notice and and I paid for another year. This year I had to make the following change.
                      Fix a 10 year old bug that didn't allow Scrollmania to move to different machines.
                      Rewrite the Load and Save functions so they no longer require flash. You apple users will like it.
                      Today, 02:06 PM
                    • jim_mex
                      Reply to FInished Product
                      by jim_mex
                      Hi Tony - I built a wedgie sledge pretty much immediately after you first mentioned it. It worked fine within the capabilities of my homebuilt table saw but I quickly realized that to get the best out of it I needed a new saw, hence my recent acquisition.
                      The videos are also on Jerry Bennet's...
                      Today, 01:15 PM
                    • jim_mex
                      by jim_mex
                      Hi planeur - thanks for the reply.
                      Just to be clear. I wasn't suggesting that you change your original sheriff, rather that you apply some of the ideas for future projects. Nevertheless you can see the difference in the modified version
                      I can definitely see in your Heron that...
                      Today, 01:07 PM
