Haven't glued this up or sanded yet. It was definitely a hard one for me to cut... no room for error as the width of the box is only 1/8 for the most part. Pattern was designed by Steve Good http://www.stevedgood.com/squarebasket.pdf I am definitely going to have to make a donation to his site... so much good stuff there.
Woven box
Sweeeeet job bstark, Steve certainly has lots of patterns, and information over at his site too. Have you checked out the Pattern Vault right here on this site yet? Members here make some nice patterns too.Gloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
Thanks for the comments.
I justs used shellac for the finish... brush on. I have been having a hard time keeping the last coat of brush on shellac to look smooth... so I have been trying urathane and maybe spraying the final coat.
by NC ScrollerGlad you got it worked out. Happy endings are always the best. Can you post a picture? It might be helpful to someone else in the future....
Today, 03:44 PM -
Reply to Minor Question About Bowlsby scrollerpeteIf the bowl is not used for wet stuff you can use Titebond glue that dries up invisible. My trick is after applying the glue and I used my bowl press from Carol, after a few minutes, release the press and use a plastic straw cut at an angle to remove the excess glue.
https://www.leevalley.com...Today, 02:08 PM -
by RoyzMGThanks for the comments. I finally designed my own tool that works great.
Today, 01:16 PM -
by RoyzMGI'm just beginning to try my hand at bowls and I've been following Carol Rothman's book on scroll saw bowls. I'm on my second bowl and now understand why you need to sand the inside before attaching the bottom ring. My question deals with gluing the bottom ring. It appears to be very important to...Today, 01:15 PM
