Starting a new dulcimer project. I plan on scroll sawing several dragons and flames on the dulcimer. I hope it turns out!
Starting a new project, a dulcimer with dragon accents.
Be sure and take and share lots of pics of your project. Welcome aboard."Still Montana Mike"
This gallery has 2 photos.-
Today, 12:13 PM -
Reply to First Project - Stretching Catby Sandy OaksVery well done, especially for your first. I too like the added detail.
Today, 11:22 AM -
by RolfThe end result is beautiful I really like that Hummingbird design....
Today, 09:54 AM -
Reply to Help with spray adhesiveby RolfI have used all sorts of methods for putting on patterns. The only time I put a pattern directly on the wood is on Intarsia as the shaping process removes it. I only use blue tape under the pattern on very small projects.
I Use clear removable contact paper (shelf liner) on the wood and...-
Channel: Beginners Scroll Saw
Today, 09:51 AM -
Reply to Sanding and calibration disk.by RolfI agree about how it was advertised, but it is my own fault, I know better. Just for curiosity I may strip the paint off and see how true the plate is.
The good thing is that while I had my saw blade off I cleaned it sprayed Crud cutter on it let it sit then wiped it off with a skotchbright...-
Today, 09:42 AM -
