this was a task , im not happy with the choice of wood, but happy with the end results, this was from a pattern by jacob fowler, i finally got flying dutchman blades and what a difference , i want to do one like this in curly maple, any tips using this type of wood , like is it hard to scroll, will the blades have a tendency to follow the curl, what blades would be best? etc.
new project finally finished
Lefty - you shouldn't have any trouble working with curly maple. Just keep the speed down and your choice of FD UR blades keep you straight and clean.
Great cuttingFred
aka Pop's Shop
Life isn't about waiting for the storm to pass...it's about learning to dance in the rain!.
by RolfA family friends father passed away and he was an avid bird carver. So my nephew is helping the family sell some of his tools. I bought this air cleaner and will b uy most of his carving knives and burrs. And no that is not my workshop! Not even close. ...
Today, 04:47 PM -
by RolfI just did a quick job on my table. Charles Hand has noticed that the adhesive on the new rolls of Contact brand shelf paper leaves a residue. He has changed to The duck brand. I just bought a roll and covered my table with it. It is a tough slick surface. It will be interesting to see how it holds...
Today, 04:44 PM -
Reply to Shawl pinsby axor
Yes, they can be used for hair. If they are made a little larger than the original, the shawl pins will work great in the hair!...-
Today, 03:21 PM -
Today, 09:21 AM -
Today, 09:06 AM -
