Liquid Barb Wire
  • Liquid Barb Wire
    Thought I would share my newest experiment and/or wall sculpture <fingers and toes crossed>…hope it turns out!
    Each of these lit’l guys measure roughly 9" x 14", including the tails. They all are constructed with the basic pattern with casual free-form cutting in the tail area. Each stingray consist of a bottom, middle section for body and then two ovals cut for the eyes…then glued up and clamped, shown in first photo.
    Once all dry the fun begins…and lots, and lots of sawdust!!! Because of the funky shape of the tail and position of other pieces it was not possible to use belt/disc sander or my flex drum sander…so me and my dremel and mouse sander became really good friends. However, by the time I completed all seven of them my hands did not like either one of them - lol!!! Sanding was tricky, even with the additional material, I still had to be careful to not sand too aggressively, so that the integrity of the MDF was not too thin and brittle...but still be able to show movement, I hope it appears so! Second photo shows the initial rough shape, with next photo showing several stingrays in various stages.
    Once I got them shaped/sanded a thousand different times…okay, an exaggeration, but my hands sure felt like it…I painted each one with a black base coat, and sanded them once again with 320 grit. I did not want to use their actual color, as stingrays are typically a sandy color to be able to camouflage in their natural environment, so I decided to use an artistic flare…blues and purples. I tried a painting technique with acrylic paint and isopropyl alcohol, which creates a soft blending of colors...let it dry and then sanded again. Thought I liked the result, but wasn’t too sure. Then decided to add a lit’l sparkle…lightly misting with silver spray paint…Oops…too much wind and paint! Tried to sand it off, no luck…then remembered I had some metallic spray paint in blue and purple. Gave it a try and it masked the bright silver, but also was covering up my painting technique. To my surprise I preferred it better and some of the painting technique still showed thru. Once dry, I added several top coats of high gloss lacquer.
    Material solved, color solved…the next challenge will be mounting. My intention is to have them floating over each other. Currently my thought process is to use a couple 1” x 3” or 1” x 4”s, cut into wavy shapes (in case some of it is visible from any view) and then mount each one at various heights using different lengths of dowel rods. Anyway, that is my plan right now…we will see if it all works…WISH ME LUCK!!!
    Thanx for letting me share and will post the finished photos once assembled. Any comments, suggestions and/or criticism are welcomed!
    ~ Kim
    www.gonecoastalart.com
    Those are awesome...You are outdoing yourself ....again!
      Great work. The painting sure brings them to life
        I'm struggling for a suitable superlative - wow just took my breath away. Reading through your post before looking at the pics I thought Nah - but wow.
        Great job.
          First I saw the title and had see what this was....Wasn't expecting much. Then I started reading, and got really drawn in, resisting the urge to scroll down to the pics. Read the text thoroughly, and when I finally got to the pictures, I was blown away...
          Beautiful..!!!!
          I can't wait to see them in their final position......!!!
          What about some really healthy fishing line... Just a thought....
          Thanks for sharing your work, and giving such a great narative....!!!
          Rock and Scroll
          My Gallery
          My Website
          Featherwood Woodcrafts
            That is super neat! Looking forward to seeing the finished product!
            Tammy
              Neat idea! Can't wait to see the finished project.
              Dan H
                Those look like they are going to be wonderful.
                DeWalt 788
                  Very unique! I really like them!
                  SQ
                  If you can't fix it with sawdust and glue, it's not worth fixing.
                    Excellent work Kim! Those look outstanding ... Looking forward to the final pics of the project. Thanks for sharing this look at your talent with us.
                    DW
                    John Wayne
                      THANX SO MUCH EVERYONE!!! Your comments are all so very generous and humbling!
                      I thought the name ‘Liquid Barb Wire’ was clever, but wasn’t sure who would check my post out…so I’m glad it caught your attention, and kept it! I know some of my post can be long, but I thought one might enjoy sharing my thought process (or maybe not ;-) and perhaps learn from my mistakes…like spray painting in the wind…NOT – lol!
                      As mentioned in my initial post I had wanted to do this piece for a long time and glad I finally got the nerve up to give it a try. I let the lacquer cure all day so hopefully I can attempt to mount them in the next couple days as I really want to have them ready for our largest area juried festival this upcoming weekend. I am hoping it becomes my 'wow' piece that grabs peoples' attention, still keeping my fingers and toes crossed that they all come together how I want.
                      Additionally, I decided to tackle a few more pieces using the additive/subtractive method; a Queen Triggerfish, Sailfish and Mischievous Grace. I am trying to come up with clever names for the first two, but it hasn’t hit me yet….any suggestions!?! Any guesses of what subject ‘Mischievous Grace’ may be?!?
                      Hoping to get some photos taken to share before mid-week…the clock is ticking too dang fast for the upcoming weekend…already!!!
                      Thanx Again!
                      ~ Kim
                        A dolphin???
                        Rock and Scroll
                        My Gallery
                        My Website
                          Wow...beautiful work and a lot of it too! You could probably make a sculpture just from the pile of sawdust you created making these! Really nice - thanks for sharing.
                          ichibob
                          aka - Bob, USAF Ret.
                          www.grandpaswoodshed.com
                            Fantastic work Kim!! You amaze me with the different things you come up with - just fantastic. Can't wait to see it displayed.
                            As for your names - I just had to click on the link because of your title. I mean, I've run across a lot of barbed wire in the woods - old fence lines that had come down. I just couldn't figure out where you were going when you started talking about your sculptures. Kept waiting to see how you were working barbed wire into them. duh... Had to go back and re-read the title before it hit me! LOL (still wondering how you are making a liquid fence... lol) Now you have me guessing on Mischievous Grace....
                            T
                            Theresa
                            http://WoodNGoods.weebly.com
                              WOW!!!!! You have far more imagination than I do. Thanks for sharing an outstanding project with us. Can't wait to see the final pics.
                              george
                              George
                              delta 650, hawk G426
                              • daveswoodworking
                                Ornament Exchange
                                by daveswoodworking
                                Yesterday, 08:12 PM
                              • sawdustus
                                by sawdustus
                                George
                                Yesterday, 12:39 PM
                              • sawdustus
                                Reply to tooth fairy box
                                by sawdustus
                                George
                                This gallery has 1 photos.
                                Yesterday, 12:34 PM
                              • sawdustus
                                by sawdustus
                                George
                                Yesterday, 12:32 PM
                                Reply to What do you make
                                09-23-2021, 10:09 PM
