John Nelson's Italian Fretwork Clock
  • John Nelson's Italian Fretwork Clock
    I recently completed John Nelson's Italian Fretwork Clock that was in the Scrollsaw magazine. I used big leaf maple for 95% of it but the base is walnut. The figure in the wood was so wonderful that I did not want to add the additional ring around the clock face. I also did not cut the hole in the back as I felt it was not necessary. The clock won a blue ribbon at the NYS Fair. For those that wonder, I counted the cuts - 242 (including the outsides).
    Here are pictures of it [I hope]:
    Barbara
    Proud user of Excalibur, RBI Hawk, & Delta
    Sorry, doesn't look like your pictures loaded. Give it another go. I'd love to see them.
    That clock has been very popular with members of this forum. A veteran member was the one who cut it for the magazine article. I recently finished it myself and pics of mine are in my thread, up in the General Scrollsaw forum.
    Looking forward to the pictures!
      Here are pictures
      Here are the pictures ... I guess I forgot to hit upload the last time.
      Barbara
        B'villeYou did that clock justice. The wood selection is perfect.
        You are right about the figure around the clock insert.
        This is a good example of taking a design and making it your own creation instead of just following the suggestions in the article. In your case wood selection and the removal of the trim ring around the clock face. Good choice on the insert I like the crazing.
        Did you scroll or turn the spacer ring?
          It is turned. We have two lathes at the house in addition to 3 scrollsaws. For the clock, it was cut on my Excalibur.
          Barbara
            Outstanding!
            You did the right thing by leaving the trim ring off the clock face. The figure in that maple is very nice!
            I too wondered why the hole was designed to go the whole way through. I almost didn't cut it, but chickened out at the last minute, worrying that I would figure out why when it was too late.
              I think the original design called for a different clock movement where you needed access from the back. obviously that is not needed when you use a snap in insert.
              Bill what did you think the hole was for?
                Well, I actually started the cutting the clock before I had the insert in my hands, so while I presumed it was to allow access, I just wasn't 100% sure if I would need it or not. I wanted to have the holes drilled before I started the scroll work, so they were done before the clock arrived.
                Ironically though, the first time I test fit the insert, two of the three little metal spring clips snapped. For a brief moment, I was kind of glad I had the access through the back, because I was thinking I might have to rig up some alternative mounting method. But one call to Klockit's customer service and they sent me a couple new clips.
                  B'ville - great clock!
                  Bill, I had the same problem with clocks from Klockit - I got 3 clocks from them and 2 clips broke on each one, 3 or 4 of them disintegrated in my fingers while I was inserting them in the clock before I ever got to the test fitting into my clock stage.
                  Harbor Freight (Central Machinery) 65406 - 26"
                  • Quartz43
                    Reply to My computer issues.
                    by Quartz43
                    Glad things worked out.
                    I just updated my older PC. The hard drive was 500 gb and eight years old. I cloned it to a one TB SSD (solid state drive). Put the cloned drive in and worked perfectly with all my old programs. The computer is now much faster. The new drive was about $100 and...
                    Today, 05:02 PM
                  • NC Scroller
                    Reply to Need suggestions or a bit of guidance
                    by NC Scroller
                    You nailed it.👍
                    Today, 04:03 PM
                  • NC Scroller
                    Reply to A new toy.
                    by NC Scroller
                    Once upon a time ( in the 70's) i attempted bow hunting. I believe the bow had a 45 pound draw. I quickly learned that it was not for me. It takes lot of hard work and practice just to be fair at it. Good is a whole different level. I hope you do better than I did.
                    Today, 04:02 PM
                  • Linda In Phoenix
                    Reply to A new toy.
                    by Linda In Phoenix
                    Now that's a cool way to maintain hand/eye coordination. Enjoy that toy--- and--- HAPPY FATHERS DAY TO ALL THE DADS OUT THERE!
                    Today, 01:30 PM
                  • Linda In Phoenix
                    by Linda In Phoenix
                    So glad you are back up and running. You will be awed by the speed of your new drive, fresh drivers, and cleaned up files. Spring housecleaning!
                    Today, 01:28 PM
