Last summer I created a scale model of an old Beam Steam Engine. They were used in England to pump water. The first practical steam engine for industrial use was developed by a Scott, Mr. James Watt. I built a plastic model and had plans for a wooden model from a gentleman in England. From these examples, I built my model with several kinds of wood. It was a fun project. I made it for a friend who is a fine wood craftsman and a steam engineer at an atomic plant. I thought some of you might like to see it. Styrk1
Beam Steam Engine Model
Very well done."Still Montana Mike"
Yes Sappy it does. When you turn the crank the two balls on the governor go around and the main beam toggles driving two other parts. The black drive belt is an O Ring that has been cut and re-glued together with Loctite Gel Super glue. Thank you for the compliment. Styrk1
That's awesome Styrk1, it covers two great passions of mine, scrolling and the history of industrial steam engines. There are lots of museums over here that have working steam engines from way back, and when ever I get the chance I visit them. When I started work in the coal mines in 1965 they still used a steam winding engine on one of the shafts. Your work is excellent, thanks for sharing.
MickI am always ready to learn although I do not always like being taught. Winston Churchill
Thank you for the compliment journeyman. I tried to incorporate the flywheel governor, the separate condenser, and the Watt linkage. It is not exact, but creating it all out of wood was a challenge. Glad to converse with someone who understands steam engines. If I ever make it to England, I will certainly look up a working engine. Styrk1
Altho the steam engine model parts spin I see you have a No Spin cup for "fair and balanced" size reference.Pacifism is great, as long as everyone is participating.
StephenD
Desert Woodcrafters
Stephen, I see you noticed.Nice play on words! I took the picture with the cup because my brother wanted a size reference e-mailed to him. He lives in another state. I grabbed the first cup on the shelf and didn't think I would be sending it to anyone else. No political bias intended. Styrk1
Clock
Hey Mick. I looked at your profile and saw you build clocks. Here is one I fretted a few years ago. Styrk1Attached Files
You have done a fantastic job of blending together two of my greatest passions, scrolling and antique machinery! Very well done Styrk1. You have inspired me to try a similar project. Thank you for sharing.Manufacturer Of Heirloom Quality Sawdust
by RolfA family friends father passed away and he was an avid bird carver. So my nephew is helping the family sell some of his tools. I bought this air cleaner and will b uy most of his carving knives and burrs. And no that is not my workshop! Not even close. ...
Today, 04:47 PM -
by RolfI just did a quick job on my table. Charles Hand has noticed that the adhesive on the new rolls of Contact brand shelf paper leaves a residue. He has changed to The duck brand. I just bought a roll and covered my table with it. It is a tough slick surface. It will be interesting to see how it holds...
Today, 04:44 PM -
Reply to Shawl pinsby axor
Yes, they can be used for hair. If they are made a little larger than the original, the shawl pins will work great in the hair!...-
Today, 03:21 PM -
Today, 09:21 AM -
Today, 09:06 AM -
