I am cutting out a 3 color design out of 1/8' vinyl (1 ft. squares ) the design is 4' sq. 16 tiles with 2 different colors added.(a puzzle) do you have any recommendations on blades? or how to do this? Puzzled about puzzles ???
cutting vinyl tiles
Re: cutting vinyl tiles
??? Piney, I have never tried to scrollsaw vinyl tile but I would expect problems with heat. If you use too much speed, the blade may get hot and cause the vinyl to melt and stick to the blade. I might suggest a coarse toothed blade, slow speed and if your saw has a dust blower, direct it into the cut to cool the vinyl as much as possible. In fact, I wonder if you could freeze the tiles first to make them chip better?
I recently retired from a owning a floor covering store and for one job I scroll sawed the logo of our local country club from 1/8' vinyl tiles. I stacked the two colors, used a medium blade and took my time. I did not have any problems with it melting. The finished logo covered about 16-20 tiles so there was only a portion of a letter on each tile. It looked GREAT! and was good advertising for my store.
Reply to hegner 2"by dwssr2I have no idea what the measurements of the 18" table are, I can give measurements of the poly max and the 14"....
Today, 05:22 AM -
Reply to hegner 2"by MidMich324Just Wondering...
With the 22" inch one you get 4 more inches of depth of cut but do you also get a few more inches of table?-
Yesterday, 09:30 PM -
Reply to Spring Issueby will8989I had to fool around with copying and taping a pattern again today. This wasn’t as bad as the fish, but still a pain. I use rapid resizer. Scan a pattern, put in size I want and it prints it out. If more than one page, it numbers each page at the top and I tape them together. Had the fish pattern...
Channel: Publisher Feedback
Yesterday, 09:28 PM -
Channel: Scroll Saw Puzzles
Yesterday, 02:51 PM -
Reply to Spring IssueRolf
Yesterday, 01:48 PM -
