Which Fine Sanding before finishing with oil
  • Which Fine Sanding before finishing with oil
    Bonjour !
    How fine are you sanding with paper before finishing with oil ?
    They say that the more you use fine paper as 240 and finer ,best is the result , more uniform and less wood contrast !
    What are your experiences ?
    I did some test on cherry on one side I stopped at 150 and on the other side at 240, better result, and I can see a difference, less contrasts !
    Merci
    planeur
    For almost everything I go to 220.
      I go to 320 and when I do charcuterie board or live edge tables I go as far as 400 and 600
        Project dependent 220 for my Intarsia 320 on flat surfaces.
          Most of my finishing is with a Mac Mop #240.
          Denny
          ArtCrafters in Dayton, TN
            On plywood I normally sand to 150 or 180. I do the same on red oak and poplar. On other hardwood like walnut, cherry and maple I will sand to 320. One of the secrets to sanding is to not skip grits so you would go 80,100, 120, 150, 180, etc.
              I go to 250 on boards before I cut them. I sand to 400 after cutting and before gluing up. Doing so many shows, we noticed the first thing someone does is run their fingers across the piece for smoothness and if a basket, around the top rung to make sure it’s perfect. Of course it is. As SLRA, for the newbies Straight Lines Right Angles aka husband, says sanding is a finishing step not correction - last part directed at me. He sands to 1000+ on his bird houses and pepper grinders and finishes with a polish. When a customer says “the basket feels soft” or checks the grinder to make sure it is wood, you know you nailed it. And it is priced accordingly.
              Betty
                As I wrote earlier, I go to 220 on bare wood. Between coats, I use 220 after first coat due to grain being raised. After subsequent coats I use either 320 or 0000 steel wool. For a final coat, I sometimes use a brown shopping bag paper.
                  Reply to Rolf,
                  Just under 2 " of rain with more on the way. We don't seem to have any flooding issues where we live. Sandy soil, 3/4 mile from the bay with decent elevation. Lots of Long Island did not fare as well according to the news. They seem to have gotten it worse west of us.
                  How about you?...
                  Today, 07:38 AM
                  Reply to Rolf,
                  That really depends on who you ask😏. If you are referring to my surgery, all is well. Thanks for asking. Technology is amazing! I just am not allowed to lift anything greater than 25 Lbs for awhile. As Murphy would have it I got a cold and sneezing is not fun. I was in the basement yesterday cutting...
                  Today, 07:32 AM
                • wjbclocks1
                  Reply to Rolf,
                  by wjbclocks1
                  Rolf ,Stay safe .sorry about the weather you are getting....
                  Today, 07:27 AM
                  Rolf,
                  Are you ok Rolf?
                  Yesterday, 05:43 PM
                • Jim McDonald
                  by Jim McDonald
                  Yesterday, 09:10 AM
