olive wood and polyurethane
  • olive wood and polyurethane
    Dose any one have experience applying polyurethane to olive wood? In my experience I have not had the best results. The finish is hard to discribe, a little rough at spots is the best I can say and maybe not drying as fast as other woods. Actually I am not sure if it ever does dry completly. The wood I am using is reject cutting boards, but I am thinking there should not be any finish on the wood, because I re-sawed and heavy sanded. thanks for any replies, dan
    I have never worked with olive wood. But I am concerned about the use of old cutting boards. I soak all of mine with mineral oil and it penetrates deep into the wood. I do know that people have wiped down other naturally oily woods with acetone prior to applying a finish. Do you have any scraps left to try that on?
      I have used olive wood for turning pens. LOVE the smell of the wood. On pens I finish with BLO and CA glue. It is an oily wood. You might need to apply shellac before the poly.
        Like Scott, I've only had Olive wood for pens. They claim it's an oily wood, but I didn't see on the blanks that I had. Just to be safe I wiped it with some acetone, which didn't seem to make a difference. Then I coated it with 5 coats of medium thick CA. They came out great.
        If your wood appears oily, you might want to try the acetone trick. I've seen Olive shine without much finish on it, so I'd bet that poly will work just fine.
        Tony
          Have they been previously used or just unable to be used or sold? What are you going to use it for? I’m with Rolf. I just soak my cutting boards in mineral oil. Why do you want to finish it? Good luck.
          Betty
            The suggestion of soaking the wood in mineral spirits sounds lie a good idea, maybe I'll try that next time. It seems as though after a number of coats of polyurethane and sanding in between coats, produces an OK finish. Nativity.jpeg
              I used minwax spray semi gloss. The star is yellow hart and the dark wood is local black walnut. dan
                Sorry i did not post this all in one reply, There is a rare earth magnet on the back to stick on refrigerator or it will stand alone. about 5" x 5".
                dan
                  That is beautiful. Where did you get the pattern?
                  Betty
                    I get a lot of my patterns/ideas from google images. I change the shape on microsoft word and change the size when I print. Just about every thing I make is modified to my liking. dan
                      Very nice project.
                        Turned out Very NICE! As Scott mentioned earlier, with problematic finishes, my standard go-to is de-waxed clear shellac for an initial coating, then poly.
                        Hank Lee
                          You have way more talent and patience than I have changing patterns. The wood selection makes it. If you ever decide to sell the pattern let me know. That could be my nativity collectible for next year.
                          Betty
                          • RJweb
                            Reply to New Band saw Fence
                            RJweb
                            Thx for the review, what size blade did you use for resawing, also I feel that is a good price considering it is a Kreg product, I like their stuff, I have a few of their products, RJ...
                            Today, 12:54 PM
                            Quartz you are absolutely right about the need for a good blade and proper tuning of the saw. I thought the price was a lot cheaper than I expected. Only nine ornaments
                            Betty I have the mag switches on my scroll saw dust collection they are amazingly strong.
                            But for my fence I want to...
                            Today, 09:10 AM
                          • Sandy Oaks
                            Reply to Gizmos
                            Sandy Oaks
                            Thanks Rolf. Hard to see, but the light wood is curly maple. Beautiful
                            Yesterday, 11:07 PM
                            will8989
                            Bruce bought the Carter bandsaw fence and resaw fence at the Woodworkers show. He hasn’t used it yet but will give his ewview when he does use it. His is magnetic as he is left handed.thats what he said anyway. Will let you know how it is when I use it.
                            Yesterday, 09:53 PM
                          • Trout
                            Reply to My truck is done..
                            Did a delivery with the new truck.. ...
                            Yesterday, 07:42 PM
