Painting and glueing scrollwork
  • Painting and glueing scrollwork
    This question has to do with painting scroll work and glueing.
    Those that paint their scrollwork, do you paint it before you glue?? Or do you glue and then paint?? Basically the question is designed around layer work or box making and things of this nature. What type glue do you use and if it is a brand what number or formula is it?? I usually do not paint my work but I have recently made a few projects that have various layers and I want to use a painted backboard on them and thus the question. Thanks in advance.
    John T.
    Sometimes to achieve the results desired on scrollwork I do paint, and when I need to I definitely do so before glue up. It keeps the seams clean and you don't have to worry about stray brush strokes. I don't however paint the areas I intend on applying the glue to. I only paint the surfaces which will be exposed which in turn leaves bare naked wood for glue adhesion. I've tried several glues, experimenting frequently, but have no distinct favorite.
    Linda at www.ArtIngrained.com
      When painting is required I paint with water based paint before assembly. I wait no less then 24 hours before assembly and weather permitting I will put the painted piece outside to aid in drying. For gluing I use titebond 2 or Gorilla brand wood glue. When gluing made sure you cover the entire contact area and not just spots. I also use a lot of spring clamps and allow to dry over night.
      • Sandy Oaks
        Reply to Colwood wood burner Great support
        by Sandy Oaks
        Good to hear about great service and support
        Today, 09:14 AM
        I was using my older Colewood Super pro II yesterday and I could not control the temperature. As soon as I turned it on the tip went to the max. I opened it up to have a look.
        Not much in the box a Transformer, a small circuit board with a few components. I decided to call the company and I believe...
        Today, 08:27 AM
        Reply to ?????? ??
        It seems that new members don't present themselves in the new members section. If anyone spots a new member encourage them to introduce themselves in the new member section.
        I will send Kaylee a note to see who is overseeing the forum.
        Today, 08:06 AM
      • Jim McDonald
        Reply to ?????? ??
        by Jim McDonald
        As you know, we lost a ton of folks during the time the board was being redone and a lot of them ended up at the Village and have never looked back.
        As far as updates to the software, I am with Scott on having no clue. I do wish some of the old timers would check in from time to time, even...
        Yesterday, 07:43 PM
      • NC Scroller
        Reply to ?????? ??
        by NC Scroller
        I know Bob Duncan used to monitor and work on forum issues. No clue who is handling it now....
        Yesterday, 05:37 PM
