next question
  • next question
    I gave a puzzle as a gift, she would like to have it glued together and free standing. It is 3/4" cherry with multiple coats of spray on polyurethane. I tried Elmer's glue, but the way I do it, I use
    Q-tips with water to wipe off the excess glue. It seems as though the glue did not want to stick to the smooth polyurethane, maybe I did not let it dry long enough or used too much water. Any suggestions what kind of glue to use or how to do this? How to avoid excess glue squeeze out? thanks for any help. dan in Pa
    The finish not withstanding the problem with trying to glue puzzle pieces together is a saw blade kerf. Most wood glues (Elmer's, Titebond, etc) requires the pieces to make even contact. NO GAPS. That won't happen because the wood that was in the kerf is gone. Also wood glues like mentioned above have to soak in to a degree to hold fast. The only way I know you can do this is with a foaming glue like Gorilla glue. It expands when it dries and fills the gap and it does not need to soak in to hold fast. Just use Gorilla glue sparingly to keep it from oozing out.
      It might be easier to just recut it, RJ
      Life Begins @ 190 MPH
        How about using 1/8 backing and glue it on
          The backing idea sounds good. It would be like doing a mosaic.
          "Time to give back."
          "Time to Give Back"
            I also like the backing idea.
            Denny
            ArtCrafters in Dayton, TN
              The backer idea also gives it the strength it needs for the pieces that would have the hanger attached.
              Linda at www.ArtIngrained.com
                Aleen's tacky glue will work. Don't thin it. Apply it with a toot pick. clean the squeeze out with a clean tooth pick.
                With that said, if some one asked me to glue together a stand up puzzle, I would've refused. It's a puzzle!
                Dan in So.Ca.
                • Dan A
                  Magazine Subscription
                  Dan A
                  Every year for Christmas my wife renews my subscription to the magazine. This year she managed to subscribe to it twice. She thinks she was able to cancel one of the subscriptions but since it hasn't arrived yet she wonders if she managed to cancel both orders. Is there a way for us to find out if the...
                  Today, 12:33 PM
                • Dan A
                  Reply to Has there ever been
                  Dan A
                  I would be curious also. Back in March of 2014 the switch on my Delta quit working. Now last weekend it quit working again. Don't know if it's the switch or not. And of course I had a request from a friend of my wifes to cut something for a little girl. We've been talking about maybe getting a new scroll...
                  Today, 12:29 PM
                • Dan A
                  Reply to Treasure hunt!
                  Dan A
                  When I got all of my dads woodworking books, wood reference books and pattern books this was in with every thing and yes there a quite a few patterns in the three ring binder.
                  Dan
                  Today, 12:19 PM
                • hotshot
                  Reply to Only an hour away!
                  hotshot
                  Look at that Curly Maple, wow!
                  Today, 12:18 PM
                • Stephanie Weaver
                  Only an hour away!
                  Stephanie Weaver
                  Drooling on my tablet!! http://www.woodieswoodshop.com
                  Today, 12:08 PM
