Whats the best paint fer a carving oil or acrilic, acrylic, acrelic(what the heck, that water based stuff) ???
Best Paint
Re: Best Paint
Welcome, Old Fred! Regarding paints, I think most carvers prefer acrylics over oils but it depends on the carver and the carving. Acrylics can (and should) be thinned with water and applied in 'washes'. This is applying several very thin coats which tints the wood without covering up the grain. Thin washes can be blended nicely into various shades on the carving. However, I see that you have a carousel horse going. I think most of the ones I have seen were done in oils and sealed with a clear varnish.
Re: Best Paint
I've been carving for about a year now. I've tried acrylics twice and always came up with a dull look. The oils gave me much richer colors. I'm working on my 13th carving and all but one have been with oils. I use a wet on wet technique to control the intensity of the color. I enjoyed your carvings. I have a 2 1/2 year old son and I've been thinking about carving a rocking horse for him. Guess I better get busy.... if I wait too long he'll be asking for the keys to my truck.
John H.
Re: Best Paint
John, I have a 3-yr old boy and another due in January, so the rocking horse bug has bitten me too. There are very few books on the market, but I can give FULL endorsement for one by Tony Dew (I 'think' that's his name)...it has '9 patterns' in the title. It goes from start to finish, from easier projects to small/medium/large rocking horses, some have rockers and some are gliders, etc. Great book. I also ordered the 'Kid-sized Rocking Horse' book by Tom Wolfe and wasn't as impressed with the resulting rocking horse. Nice to have both as a reference tho.
Good luck,
Brian
Re: Best Paint
Oops...I forgot to mention the 'good' book is currently out of print. I couldn't get it from Mountain Heritage Crafts online, but a buddy of mine has it and got it at BarnesAndNoble. I have one on order and have been told it takes 1-2 weeks to get it. Hopefully they come thru! I'll post again if they send me a note saying they can't get it.
- Brian
Re: Best Paint
we have used acrylics on a lot of things and then I usually spray a coat of semi-gloss or gloss on it...I carved a fish however and could not get the blending the way I wanted so I used my artists oil paints (been painting 30+years) and I think that is just habit, but works great. Also just bought some Chroma paint, designed for airbrush, but haven't tried it yet. See I tol ya i used earl and late x
Re: Best Paint
The best paint is the one you feel comfortable working with. I will say this, no mater what you use you should seal it first so you get an even color. If you don't seal it the wood will asorb the color uneaven and give it a splochie look. This gos for stains as well.
Re: Best Paint
REGARDING THE PAINT ISSUE, WHEN I FIRST STARTED I TRIED OILS AND DID NOT HAVE GOOD RESULTS SO I STARTED USING ACRYLICS. I LIKE THE ACRYLICS ALOT BETTER THEY ARE ALOT LESS MESSY,DRY QUICKER.AND ARE EASIER TO CONTROL.WHAT YOU HAVE TO DO IS PUT SMAALL AMOUNT IN CUP OR WHATEVER I USE THE LITTLE SOLO PLASTIC CUPS THEY PUT TO GO SAUCES IN (I BUY THESE IN BULK AT SAMS),AND THIN TO A STAIN.TEST ON SCRAP FIRST YOU SHOULD SEE THE GRAIN THRU THE PAINT YOU CAN ALSO WIPE WITH PAPER TOWEL AND SOAK SOME OF THE PAINT OUT.OKAY WHEN YOUR CARVING IS PAINTED AND COMPLETELY DRY, DIP THE CARVING IN LINSEED OIL WITH BURNT UMBER PAINT MIXED IN (OIL BURNT UMBER). THIS WILL KILL THE DULLNESS AND BRING OUT THE COLOR ALSO SEALS IT.
Re: Best Paint
To Whitllin,
I use a fity, fity mix of clear polyurethane and lacquer thinner. It penatrates the wood deeply and dries fast, two hours and you can lightly sand it and put a second coat. This keeps the grain from rising when you paint with water base paints and you get an even color with out sploching.
by RolfA new member ralph123 left me a private message. Asking if I still provided kits for the Wooden gear clock in the Summer 2013 issue if SSWWC.
Ralph I sent you a private message.
Yes I do still make the kits.-
Channel: Author Questions
Today, 08:49 AM -
Reply to A Bear In The Woodsby RolfI checked out that site and found a CNC/ SVG file for $1.99 plus $25 shipping! for a digital file NOPE....
Today, 08:38 AM -
Yesterday, 10:53 PM -
Yesterday, 10:43 PM -
Yesterday, 01:10 PM -
