I'm a novice caricture carver, using Ceramacoate paints for finishing my work. I have used 'Flesh Tone' and 'Tomatoe Spice' shades for the flesh colors. They work o.k. but all of the carictures are looking the same. Can anyone tell me how to achieve flesh tones for Afro-,Native-,Hispanic-, and Anglo Americans? Your help would be appreciated..Nelson G ???
Flesh Tones
Re: Flesh Tones
If you are using washes and not applying the paint as a solid color, there are a couple things you might try.
First, apply a pre-wash over the entire carving using burnt umber or burnt sienna. Let it dry a little and then apply your flesh and rouge over that.
Secondly, you only mentioned one red. If that is all you have, you can vary the value by adding a tiny bit of white or black.
Re: Flesh Tones
I've never found a flesh tone that I like right out of the bottle. For most, I mix burnt umber into it - more or less, depending on the skin color I'm trying to achieve.
Teri"Santas for the Soul" &&Original Carvings by Teri Embrey&&http://www.teriembrey.com&&[email protected]
by RolfA family friends father passed away and he was an avid bird carver. So my nephew is helping the family sell some of his tools. I bought this air cleaner and will b uy most of his carving knives and burrs. And no that is not my workshop! Not even close. ...
Today, 04:47 PM -
by RolfI just did a quick job on my table. Charles Hand has noticed that the adhesive on the new rolls of Contact brand shelf paper leaves a residue. He has changed to The duck brand. I just bought a roll and covered my table with it. It is a tough slick surface. It will be interesting to see how it holds...
Today, 04:44 PM -
Reply to Shawl pinsby axor
Yes, they can be used for hair. If they are made a little larger than the original, the shawl pins will work great in the hair!...-
Today, 03:21 PM -
Today, 09:21 AM -
Today, 09:06 AM -
