I'm going to make a set of black bear yard shadows. I plan to use 3/4" exterior plywood and black exterior paint. Do I need to apply any thing on top of the exterior paint for more protection from the elements?
Finish for Yard Shadows
Hi Sonja,
That would depend on the type of paint used :-)
Actually if you use a good grade exterior paint, you should be Ok. You could always add a UV protector on top, but I think it would be overkill.
Just be aware that you will need to re-finish them eventually, quicker if they are in direct sunlight and very exposed to the elements, less often if for example they are near a fence that puts them in shadow and protects them from the elements.
Also, the better you prepare the surface, the better the results. Sand the surfaces, use a good primer, allow to dry well between coats and lightly sand (don't forget to wipe off before the next coat).
If they are to be in/on the ground, you might want to use a 2 part epoxy as a sealer on the edges that will be touching the ground. This will prevent water from seeping in.
With all that, and if you don't leave them outside for the winter (depending on your location) you should be good for quite a few years.
Regards,
Marcelhttp://marleb.com
Inquiring minds want to know.
KarlYesterday, 08:15 PM -
Reply to Looking for compound cut ornamentsby Sandy OaksSo sorry for your loss. Sue Mey also added new compound cut ornaments that I thought were unusual. Here is a link: Compound cut ornaments #19 (scrollsawartist.com)
Yesterday, 10:15 AM -
Reply to Wood lampshadeby planeurFinish product : what would you use for the finish product , as on cherry or ebony? I like usually oil product but I did some tests with gloss varnish and It is quite good , because all the yellow and black base is quite glossy.
I have lot of fun to create the shade , by doing a lot of...-
Yesterday, 09:14 AM -
Reply to Looking for compound cut ornamentsby meflickThanks for adding the Ornament Book Don, I had forgotten it has some compound patterns in it,...
03-20-2023, 11:31 PM -
Reply to Alex Fox Basket C16by Sandy OaksThanks for the nice comment. Actually, not very fragile....03-20-2023, 10:57 AM
