Grain Raising Problem (help please)
  • Grain Raising Problem (help please)
    Carving basswood or cypress, in particular..
    after the carving is complete, and using acrilic (water based paint) i get a lot of grain raising but on bass wood in particular the fine fuzz raises and turns to a felt looking lumpy mess, how can i stop this?
    painting, sanding repainting and resanding final coat. gets too thick and i loose the fine detail lines ive spent hours to carve in to the caracature to detail faces pocket lines and clothing seams...
    thinking of trying to seal the caracature just after finishing then sanding
    any suggestions ? ???
    Re: Grain Raising Problem (help please)
    Can't speak to cyprus, but on basswood, have never had a fuzz problem, and I never sand my caricatures. If your getting fuzz, it may be from the sanding, tools not quite sharp, or not minding the grain while carving. That's pretty ambiguous, but the only things I can think of.
      Fuzzies on Basswood.....usually when powercarving against the grain, but can occur on end grain cut by edged tools too. Solution...seal the wood before painting, then sand lightly to remove the fuzzies, then 'wet sand' using a lubricant. This re-seals the wood and gets a better surface and the small little fuzzies that dry sanding can miss. If you use an oil based sealer and lubricant, there will be less fuzzies, water seems to make 'em multiply!
      Wipe dry and let sit to dry completely...then you can paint away and it shouldn't raise any more fuzzies.
      Good luck,
        i agree with Bob the fuzzies occur when power carving or sanding i usually will seal with Deft and will sand again if neccessary then apply a second coat of Deft if necessary before painting
        Frank
          You're getting fuzzies on your cypress knees? Like the others, I've only got them when using power or sanding, and the sanding only really causes fuzzies on the knees if its real humid or raining. I guess the wood sucks up a little of the moisture in the air.
            Thanks for all the thoughts and suggestions, on the fuzzies..
            some thoughts on weather conditions i feel a lot to do with it is humidity, here in central louisiana, its suppose to be our dry season, with little humidity, but this year is weird, so we get a dry day, and humid days, due to me carving in the house and outside compounds the humidity issue. of course leaving the carvings on the front porch one evening late, cant be good for them ither.. i got them in before the due got on them, but i mostly carve on the porch and watch the world go by....
            but additional shortcommings on my part, are probobally my own downfall,
            on good sharp tools, Clean carving on cypress takes the fresh stroping every few cuts it seams or the wood tears,
            where i have found with basswood you can go longer between stropings and still work seams to be uneffected,, aperently untill the water base acrilic gets on the wood and raises the grain,
            i have used 150 & 300 grit film, on the raw wood caracatures before painting, and it seams to worsten the raised grain, guess ill experiment with the matt finishes to seal, or linseed, tung oil 'as its not water base as mentioned' as far as i know, maybe i'll get away with using it as lubericant....
            not a major thing i guess but a darn well aggrivating bump in the road.
              Cut some 2' diameter maroon colored scotch brite pads and put two of them together in a dremel tool and go over the carving. Then use a coat of boiled linseed oil, and wipe off right away. Let dry for a day. Paint with thinned acrylic paint. Then spray with two coats of sealer. My two cents. Big Al
                Thanks al,
                I havent tried the scotch bright yet, i can see a small problem with that though,
                i carve lots of small things with small digits fingers and such, and i think the scotch brite might snatch them off, its hard enough to find a arm in the chips, but a finger smaller than a grain of rice flung across the room/.
                basswood in the south is hard to come by localy, for $20.00 you cant get enough to heat a pot of coffee..
                its expencive so i use every scrap, most times carving minature people the size of your index finger. presently im to a project of carving the animals from a louisiana swamp farm setting at about the same scale as the finger lingth people...
                and the grain raising? will remove lots of details,
                ok, i did try the sealer, although after getting home with it i seen its waterbase, i tried it on a small racoon, and used 300 grit paper on it after drying. seams to have helped some.
                ill try the boiled linseed oil. on the next one.
                i rough out 4-5 charters a day before i burn out, or they all start looking like cats..
                then let them set overnight before detailing, and painting.
                then its several days to wait to see if i got the color scheame right or more detail is needed to be redone,, so about a week per item over a month..
                thanks
                  Hi Big Al...I was wondering about your treatment of linseed oil prior to painting with acrylics. I've read where you can put oil paint over acrylic but the other way around is a no-no. Have you ever experienced any problems with adhesion?...Reg
                    I regularyly use boiled linseed oil and then paint with acrylic paint. If you want the wood grain to show through then use a wash. 3 drops of paints per tablespoon of water. If you want to cover the grain paint full strength. No problem adhering. There can be problems if you try and put a shellac over the acrylic.
                      Thanks for the new comments,
                      Another new charter and still got the fuzzies.
                      even after sanding, fine 150 grit mainstays contour sanding sponge
                      the effect is simular to when you scrub too hard on paper when water coloring during the time the paper is wet the results has a felt like appearance. and some ultra fine sawdust clumping, bumpy looking paint..
                      I may be causing my own problem carving these caratures too small so every defect seams to be a giagantic one.
                      the men folks are about scale to my index finger kids and animals are in scale to the men folk..
                      maybe you call it trifty. cheap, i think its gaining experiance the best way on what the wife leaves me for plating around money... hahah
                      the racoon seamed to be fine after coating with waterbase sealer, but the sealer was so thick i lost the eyes claws and fingers..
                      cutting it with water seamed to be a de-ja-voo thought, been there...
                      ill get out the boiled linseed oil,.
                      the paint is new acrilics, or bought this year. maybe i got bad paint?
                      maybe ill get some photos of this problem on my pictrail if i can get my camera to show it.
                      thanks to all again...
                        Thomp2-on your next project use a non water based sealer
                        you may still have to do a little sanding,but i use Deft and it seems to hard up the fuzzies and they are easier to sand off-or buff with a scotchbrite pad.
                        Frank
                          maybe this works.
                          [hr]
                          http://www.picturetrail.com/gallery/...&members=1
                          [hr]
                          Above is the problem i have with grain.
                          it appeared after the paint was dry.. not sealed, before or after, hope this explains better what i was discussing.
                          working on the flannel looking problem but camera is so cheap... enlargements are done with magnifying glasses...
                            Thanks for the reply Greyhair.
                              I'm not an expert by any means, but the hair 'fuzzing' looks more like a sharpening problem. I have a wretched time keeping my v-tools sharp, and when they get bad, they tear the wood like what shows up in these photos. Also, some wood is just harder to do texturing. You might try starting the hair texture with a veiner and see if you still have this problem.
                              When I have fuzzing on basswood, I spritz it with an acryllic matt spray lightly, let it dry, and use Scotchbrite like has been described already. When you get to textured carved areas, slow down your power carver and just go over it once WITH THE GRAIN--Not against. For larger, smoother carved areas, I usually just use a piece of Scotchbrite by hand OR...a wadded up piece of brown paper bag to burnish it.
                              Good Luck.
                              Donna T
                              • Linda In Phoenix
                                by Linda In Phoenix
                                New toys sometimes become tools we can use, and other times they simply are tools toward expanding our horizons and being there when an idea pops into our heads. Let us know what you try the Ortur on and how it does. I'm sincerely curious. Also....why did you choose Amazon vs the other vendors...
                                Yesterday, 11:47 PM
                                What is it?
                                Bruce was bored and made this. What is it?...
                                Yesterday, 10:57 PM
                                Reply to First you need to make a mess
                                It was a challenge that’s for sure. I didn’t start anything until I was all finished. It’s nice to have a clean area to work in! My biggest challenge was all those pieces of scrap wood that I just might need “someday.” They burned well in my son’s woodstove. And I did get through all the patterns....
                                Yesterday, 10:54 PM
                              • tgiro01
                                by tgiro01
                                Wow - Betty, what do you charge. I have things to do and I'm in the process of cleaning my shop, just to have room to do it. My problem is that I get the work bench cleared and then start working on projects again. I really need to do the workbench last.
                                Yesterday, 10:05 PM
                              • tgiro01
                                by tgiro01
                                I ordered and received the ORTUR Laser Master 2 from Amazon, the but haven't had a chance to even get it out of the box. Too much going
                                on right now. I got the 20 watt version, which is supposed to be good for cutting, but I don't think I'll be doing much of that. There will be a learning curve...
                                Yesterday, 09:57 PM
