Finish for Purpleheart?
  • Finish for Purpleheart?
    Greetings, all. I seem to remember that a month or two ago somebody mentioned in some thread a good UV-protective finish that would keep Purpleheart (and undoubtedly other UV-sensitive woods) from fading as quickly as it would with other finishes. But now I can't find that thread. Or maybe I dreamed it. Any suggestions for a finish for Purpleheart?
    Of course, not displaying the piece in direct sunlight is a gimme, but even ambient sunlight will cause it to fade. I do like the color and I'd like it to remain purple for as long as possible.
    ThanKS all!
    Kevin
    Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. -- Dr. Seuss
    NEW DeWalt 788 and that old, Jimmy- Jerry- and Kevin-rigged Delta 40-560
    Id suggest a poly that is labled 'spar' , thats intended to be used in applications where sunlight is an issue. Dale
      I think, that Dale was referring to the "Marine Spar Varnish".
      From the information that I have gleamed regarding UV protection (inhibitors and blockers) on those woods that change color. A few years is all you will get from them.
      You might want to try making up a purple pigmented stain sample, and then use a flat sheen coating, the pigments in the stain and the flattening agent in the coating are both blocker of UV rays and will give you some protectiion against color change.
      Good Luck
        Mac - thanks for that bit of information. Finishing is something I always struggle with. I have an upcoming project that uses Purple Heart and this info will come in handy.
        Paul S.
          Purpleheart
          Paul,
          Happy to help.
          Mac
            I have some purpleheart with spar and it turned brown after two years without being close to a window. I have purpleheart with tung oil finish after 5 years and with tons of indirect sunlight and it's still the same purple it always was. I have read that tung oil is an excellent UV protectant and it soaks into the wood to lock in the color, where Spar sits on top, breaks down and then fails to do it's job. I have settled into an undercoat of formbey's tung oil on all my intarsia's and then I spray poly on top. The tung oil is so easy to apply too, and if you do several coats, the tung oil is plenty hard to be a top coat too...sometimes that's all I use. If you topcoat it on top of tung oil, wait 72 hrs. And the odor is somewhat repulsive!
            Jeff Powell
              Thanks, guys. I kind of like the tung oil idea, partly because Jeff has already done the "experiment", but probably also because of its simplicity. (I'm in a Danish Oil rut right now.) I don't have a lot of experience with stains but that's a reason to try Mac's idea, too. Since I plan to be cutting for many years, I'll probably do my own experiment. I'll let you know in '09 of the preliminary results.
              Kevin
                Tung Oil is the best UV blocker?
                Tung oil is an amber color coating, any one who uses tung oil or boiled linseed oil knows both of these coats darken as they age, no matter what wood you use they will amber, that includes purpleheart. Which, means the color could not be the same 5 years later, even if it was not in the sunlight.It would have darkened from the tung oil any way
                You might have a bottle of "magical" Tung oil, what company is the bottler of the tung oil. I want to ask them if they know that their "Tung Oil" is the best UV blocker coating that is sold, after 5 years the purpleheart wood has not change even being in the sunlight.
                Even the best UV coatings only last a few year, then the chemicals break down and become useless.
                Will you post the name of the company, what a great article that would make if it checked out.
                  Like I said, I use formbey's and then poly over top. I'm not interested in arguing about it, just telling how my results have been so far and I am very well pleased.
                  Don't think formbeys is pure tung oil, and haven't noticed hardly any ambering. the purpleheart has stayed the same, the bloodwood has darkened some though.
                  Jeff Powell
                    It doesn't make sense to argue with experience anyway. As they say, experience is the best teacher.
                    Mike
                      Tung Oils
                      I'm not hear to argue with you or anyone else.
                      As I mentioned, 100% pure Tung Oil or any modified Tung oil will both yellow (amber) by adding Poly over either of these coatinga it will yellow even more over time, this alone will darken the coatings and change the color.
                      If you use an "Acrylic" coating they are all water clear, and will stay that way for years, the purpleheart will change colors one way or the other.
                      And, Fromby's is modified, its not pure Tung oil.
                        You can also try teak oil work great with dark woods. Its made for finishing teak Boats so it holds up to UV real well just my 2 cents
                          Dry Oils...
                          There are several drying oils that are used as coatings on wood, Tung and Boiled Linseed Oil are two common ones. If the linseed oil did not contain a "metallic drier" which causes the oil to dry faster it could not be used as a coating because it dries to slow. ( it is not "boiled" that's just a fancy name)
                          Manufacturers use many different names for these two oils, in many cases they add solvents and resins to these two drying oils, which changes the two oils making it thinner or thicker, lighter or darker in color, some manufacturers use a dye to add additional color to these coating. They give them names like Danish, Swedish, Teak, Walnut, Maple, Oak, and many other names, they are no more then just different names with a different formula.
                          They are very popular coatings because they are very easy to use, in most cases they do not contain UV inhibitors or blockers, some exterior coatings like marine or exterior varnishes may have some, they are usually very expensive.
                          Many scrollers that I know use drying oil coatings just as the base coat to seal the wood, and then use lacquer spray cans as the final coating for their work, while there are others who use the drying oils from start to finish to complete their projects.
                          I'm only trying to pass on some information about drying oils.
                          www.macsimmons.com
                            Teak oil comes from the natural oils in the teak tree and all teak oil has UV inhibitors because it is a natural occurance coming straight from mother nature. Tung oil comes from a tung nut and does not have natural UV inhibitors, but many companys add it into their reformulations. Formbeys tung oil finish, which is not pure of course, did have a UV, but no longer do they add it for some reason...the lady at formbeys said she thought is was a measure to keep the price down.
                            Otherwise, the rest of the oils are pretty much like you say, a conglomeration of one or the other or sometimes a mixture of both at the same time.
                            Still a good topic, because now when I run out of my tung I'll know not to buy another bottle of formbeys..I'll switch over to the teak oil which I have used and like it just as well. It's all about the color protection for me, not so much whether one is better than the other. I won't be searching for a new brand of tung oil that I might have to order online when I can just go to lowes and get some watco teak oil for $8 - $10.
                            Jeff Powell
                              Jeff, I am only trying to help..
                              Jeff,
                              I tried to explain here, that manufacturers can call a product Tung Oil,Teak Oil, Danish Oil, or any other oil, and there does not need to be any of Tung Oil or Teak Oil in the product at all. In some cases, an "essence" is added to give the product the smell of that ingredient.
                              I am going to attach two MSDS (material saftey data sheets) from a well known manufacturer, if you look at the ingredients of their danish oil and the teak oil, you will see they are basically alike, you will also notice there is no teak oil listed. THEY ARE LISTED ON THE FIRST PAGE.
                              Many manufacturer do this, I am not picking on Briwax, I am only trying to enlighten you and others that its easy to be fooled by what they are trying to sell you.
                              When in doubt, ask for a MSDS, you are entitled to one by law.
                              I'm just trying to help.
                              • handibunny
                                by handibunny
                                Rolf, smaller bowl-cutting angles, 30Ëš or less, usually don't present a problem either with vibration or for cutting into the table. It's when you get into the 40Ëš and 45Ëš range that things get dicey for both. (The Seyco saw doesn't even cut bevels greater than 35Ëš or so!) If you add even a slight...
                                Today, 09:21 AM
                              • Bill Wilson
                                by Bill Wilson
                                Today, 09:06 AM
                                Carole Your hole size was a concern when I purchased the Pegas Replacement Table for my EX21, because I had cut into the side of hole on the original table, The damage I did to the old table was due to the blade adjustments were not in the center of blade holders. So far that has not been an issue...
                                Today, 08:40 AM
                                That is an interesting point Carole. I have done some bevel cutting on the EX and can't say that I have experienced an increase in vibration or any problems with following the lines. I know when I cut one of your bowl designs on my Hawk I really had to concentrate on not pushing down hill....
                                Today, 07:28 AM
                              • handibunny
                                by handibunny
                                Just a word of caution about the size of the blade hole. When I used a DeWalt years ago in the infamous community woodshop, and also with my more recent experiences with the Jet, if you do much bevel cutting at a steep angle, you will cut into the table. That's why inserts have the slot that can be...
                                Today, 06:21 AM
