Wooden Gear Clock finish?
  • Wooden Gear Clock finish?
    Hello Everyone!
    I have most of the pieces cut out for the wooden gear clock in the latest issue of ScrollSaw magazine. The next step says to finish the pieces using aniline dyes and denatured alcohol. What exactly are aniline dyes and how is the author applying them? I am thinking he used a pan and dipped the pieces in it. Then the author says to apply several coats of shellac to all of the surfaces except the teeth. Is he refering to the shellac in a can, and how is he applying the shellac?
    Sorry for all of the questions but I am anxious to get the pieces cut out and the finish applied so I can put the clock together and see if it runs!
    Thanks so much!
    Nate
    -Nate
    Hawk 226
    (2) Dewalts
    You probably have a few of these finished by now!
    Analine dies are powdered dies disolved in water or alcohol, that when wiped onto parts (dipped or brushed), provide stains in a range of brilliant or natural colours. Prone to fading over time, they are none the less invaluable. Most of the wood supply places like Lee Valley, sell them.
    You could use any shelac product that dries and builds. I keep real shelac around so that's what I use. Shelacs tend to go off, so if using a product in a can, test it to see that it dries readily. Then just follow the instructions. I would personally stay with clear shelacs for these pieces.
    If you look at the designer's website, the pictures there show these clocks with rather poor finishes, just the result of the lighting conditions of the photographs. It does indicate that heroic efforts at rendering each piece to look like a piece of miled lexan were not made.
      Let's keep all of this information together??
      There is already a thread started on this clock project and it would be a lot simpler for folks to access the information if it were all kept together in one place. Let me suggest that further responses be posted to the following:
      WOODEN GEAR CLOCK
      Thanks!!
      • evilbadger
        Reply to Marc Tovar's MLT-13
        by evilbadger
        I don't remember which one I used but I think it was somewhere around #12 which is .029 diameter. Anything between 12 and 19 will work you would just adjust your slot width. There is a pattern for bending it to shape do you have that?
        Today, 05:12 AM
      • hotshot
        Reply to Old wooden plates.
        by hotshot
        Very Nice cuttings. I think my favorite is the train.
        Yesterday, 09:22 PM
      • Eugene Downes
        Old wooden plates.
        by Eugene Downes
        Over the years I've found that cutting old wooden plates can be very rewarding. Most of them are very good wood and when you finish your cut out the plate already has a nice finish on it.. I normally buy mine at yard sales or Good Will whenever I can find them....
        Yesterday, 06:45 PM
      • Eugene Downes
        Reply to Squaring scroll saw
        by Eugene Downes
        I've found in the past that you can find some very nice wood from old wooden plates. When you finish your cut out the wood already has a nice finish. I am only adding a picture of 6 but I have done many of these....
        Yesterday, 05:53 PM
      • RJweb
        Reply to Happy day
        by RJweb
        Betty, glad to see that you are having a good day, best of health to you SIL, RJ
        Yesterday, 10:46 AM
