So far all I've done for finish is dip my fretwork pieces in mineral oil and hung to dry. I'd like to try putting stain on them. How do you rub this into a piece of fretwork? Also how do you get the stain into the cuts? Thanks Enaid
finishing fret work
Minerial Oil ?
I think, you might want to consider switching over to one of the "drying oils" rather then using the mineral oil, using drying oils will cure the mineral oil never dries, the drying oils will protect the stain and also will become a permernent coating on your scrolled pieces. You won't have to keep reapplying the mineral oil as it dries out.
Good LuckLast edited by MacS; 11-22-2006, 11:35 AM.
enaid, if you have applied mineral oil to the wood staining it now will do very little. You should apply the stain first. I would dip it in the stain then use a small, dry paint brush to remove the eccess stain. However you do it try it on a scrap piece first. Good luck with it.Mick, - Delta P-20
As Sandy suggested, your best bet is to buy a disposable aluminum roasting pan. They are pretty cheap and last a long time for this purpose. Make sure all the saw dust and frizzies are removed from your fretwork piece. Then pour enough stain in the pan to slosh the piece around in to cover all the inside cuts. I usually tape a sheet of waxed freezer paper to my work table and tape several layers of paper towels over that. Sort of shake off as much of the excess stain as you can, then lay the piece face up on the towels and wipe off the remaining excess stain with a lint free rag. The paper towels will wick the excess stain fron the inside cuts. Don't let the piece dry on the towels as it will stick to the back. Move it somewhere else to dry. Then fold the freezer paper and towels up and discard them in a safe manner. Pour the stain left in the pan back in the can and wipe the pan out and save it for another project. No muss....No fuss and easy as falling off a log!!!!If it don't fit, don't force it....get a bigger hammer!!
Using a brush
You might also want to have a brush handy, when the scrolled piece is inside the aluminum pan with the stain, if the stain don't take into any places, then force the brush with the stain into those frets or any other part.
If the stain for some reason does not penetrate into the deep corner of the frets, try a piece of dental floss soaked in the stain, and then pulled thru should color it.
Wear a pair of surgical gloves when using the stain.
Add colour?
Originally posted by enaidSo far all I've done for finish is dip my fretwork pieces in mineral oil and hung to dry. I'd like to try putting stain on them. How do you rub this into a piece of fretwork? Also how do you get the stain into the cuts? Thanks Enaid
Morning Enaid,
I am not sure if the "stain" you are talking about wanting on your fretwork means that you want to add colour to your scrolling or whether you are talking about a final finish.
I have written an article on finishing fretwork for SSW&C, (similar to the Sand Shading article) I am not sure when Shannon is planning on publishing it, or in which issue, but I in the meantime I would be pleased to assist you with this if you are looking to add colour to your work.
Take care
Toni
Reply to Bruce doing greatby meflickGlad to hear all is going well for Bruce. No hiding the meds. 😉
Today, 11:04 AM -
Reply to Looking for Feedback ...Well ... I am SO glad we tempered our enthusiasm. Show is cancelled. Apparently, things did not go as planned. Maybe next year.
Yesterday, 10:30 PM -
Reply to Bruce doing greatby RJwebGlad to hear that, now be a good nurse, lol, RJ
Yesterday, 07:49 PM -
by will8989Got to hospital at 5 and office didn’t open until 5:30. Could have slept to 4 instead of 3. Right knee replacement. Surgery was at 7, he was awake and up by 10:30, pt and out the door by 12. Not much to do today except take meds, and walk 10 minutes an hour. His knee has to bend back to 120 deg. Due...
Yesterday, 04:31 PM -
This gallery has 2 photos.-
Yesterday, 12:13 PM -
