I mixed up some dye powder this weekend. I put it in denatured alcohol as suggested by the instructions on the dye. My question is - I put the mix in mason jars. Is this a good way to store the unused dye?
I put the sealed lids and rings on the mason jars, so I'm not worried about evaporation. I'm more concerned with the lifespan of the dye. Will it last awhile after being mixed?
If the bowl is not used for wet stuff you can use Titebond glue that dries up invisible. My trick is after applying the glue and I used my bowl press from Carol, after a few minutes, release the press and use a plastic straw cut at an angle to remove the excess glue. https://www.leevalley.com...
I'm just beginning to try my hand at bowls and I've been following Carol Rothman's book on scroll saw bowls. I'm on my second bowl and now understand why you need to sand the inside before attaching the bottom ring. My question deals with gluing the bottom ring. It appears to be very important to...
I have a 20" Delta that I made Judy''s "Hidden Forest" with. Took me all of 9 months of trying to find the right wood,etc.
You could use a 16" saw as you can break down the pattern and pieces into smaller sections.
