I have a question I just bought a back issue of Scroller and Santa is in it ( issue # 37 ) so what stain do u use on the white to get that smooth finish? Its awesome
White Stain ?
Old Master's Pickling White stain is fantastic for a white stain! Carter Lumber in Mogadore, near you, carries it. Not sure if Hartville carries it.
Paul
If you can't get Old Masters Pickling white poly gel locally it is available by mail order from Judy Gale Roberts at Judy Gale Roberts Intarsia. It provides a beautiful white finish and allows the grain to show through. I use it a lot.
Jan
Reply to The Vikingby RolfThis is the definition of spalting, Basically it changes the color of parts of the wood as it decays. Turners love it.
"Spalting is any form of wood coloration caused by fungi. Although primarily found in dead trees, spalting can also occur in living trees under stress. Although spalting...-
Today, 09:10 AM -
Reply to Vasesby Gary beasleyYou should try the dragon vase pattern as well. I first made mine after Steve published his first pdf vase book by swapping in one of his dragon motifs from the online library. Thats a really good way to increase your supply of patterns. I think Steve liked it because the dragon was included in the...Today, 08:33 AM
by evilbadgerJim
DON'T USE MDF for that stick with real lumber. If the roof ever developed a leak that MDF would be the first thing ruined....-
Today, 05:50 AM -
