I would like to sand but not by hand. I have two mop things, 120 and 180, I am going to get a higher/lower grit soon. It does make the outside nice and smooth. I am doing fretwork with pine and nothing that would break easily. How do you get inside and sand? I thought I read something about something that would sand the outside and the inside. I have some hesitation lumps here and there, I know I will have to do some hand sanding, some of the areas are so small that there isn't a dremel bit small enough to fit, or it will fit up to a point and then it gets to narrow. Any help would help, I just don't like hand sanding much
I moved your thread to a more appropriate forum to maximize traffic and get you more responses to your request/question.
