I got this Ebonizing recipe with a pattern...
This solution works on Aromatic cedar, Butternut, Cherry, Mahogany, Oak, Walnut and Maple...(but does not work on Poplar)...
Put a cource steelwool pad in a plastic jar with a plastic lid, this is best to use because the lid won’t rust. Add enough ordinary Vinegar to cover the steelwool and loosely cap. Set aside for a day or two. Strain the vinegar throught a cloth, don’t squeeze the vinegar out of the pad or you may get bits of metal in the liquid, which will rust.
Brush on the vinegar solution, the wood will turn black resembling ebony.
Note: The wood must be sanded as the solution dosen't work well on planed wood..
Diluting the solution with water creates a lighter shade...
