I have started using waterbased varathane on some of my project. I do not like the clean up of the other products.
The only problem I see so far is the grain of the wood swells when it is applied.
The fuzzies that are formed can be sanded off but if you sand too aggressively you end up cutting through the finish and back to the wood.
I have found that if I "sand" with a brown paper bag it knocks the finish down without penetrating it. It works really well between the last few coats too.
looks lite that long lost Hand Rubbed Carpathean finish from days of yore.
