Need advice...
  • Need advice...
    My so is getting married this fall and they want a ring box similar to the photo. Making the box is no real problem, but getting the wood ready is. I have a chunk cut from her grandfather's property, but in three days it is beginning to check.
    Can I dry these chunks in a low oven without it further damage. I have 3 pieces cut for the box and another 30 inches uncut.
    Thanks in advance.
    This gallery has 1 photos.
    You can try but I think it will crack. Round tree section tend to crack along a radius.
      If it's from a branch it will probably keep cracking. A branch grows with a different kind of stress stress on the top vs the bottom. This causes the wood to crack as it dries.
        These are fresh trunk slices if that helps.
          Not sure if this will help in your case but there is an old turners trick for turning green wood. They rough turn their project and then put the project in a brown paper bag filled with the wood chips/shavings that they just removed during the turning process. The nag is then put in a cool dry place. It would mean you would have to sacrifice a couple slices.
            There are all sorts of tricks the turners use. Mostly we cut out the center of the log. But people slice then soak in alcohol to absorb the moisture, Seal the ends of the log and put aside for an extended period of time, do an on line search. Or find a dead branch that has dried slowly ,naturally.
              Jim, if all else fails, try this link://birchbarkstore.com/collections/tree-slices-log-rounds-slabs-tree-stumps
              I've bought lovely aspen and Balm of Gilead rounds from this site to use for live edge bowls. The owner, Rene Guay (pronounced "Rainey") could probably fabricate something the size you need, and guarantees that there will be no cracking. He can be reached at 207-668-9088, or [email protected]. He sources his wood from a plantation in Maine.
              I haven't been in touch with him for a while, but he might remember me by name. This might or might not be a solution for you, but at least it's another option to try.
              Carole
                Thanks Carole!
                  Wood cracks because the outside (and ends) dry faster, get smaller. The inside wood applies pressure and the wood splits. If you can slow down the drying process you can get the wood to have the same moisture content. When I dry wood I spray paint the ends and place in a plastic bag. I open it once a week to let the air out. You could also soak the wood in poly ethylene glycol (PEG). It replaces the water in the wood.
                    Reply to Tough Decisions
                    Scott, I was referring to her pms to Bill Wilson and Quartz. They posted her reply by pms instead of on here.
                    Would be nice Quartz. I asked got Bob to put the issue next tp patterns and he said something about real estate. He found a way to do it and didn’t lose any real estate. Guess they don’t...
                    Today, 10:57 AM
                  • Quartz43
                    by Quartz43
                    I would be pleased if FC at least did a trial of printing A pattern on regular sized text and also providing a scale up factor. Their resistance to do anything if a real pain. It was a similar lack of action with the website that resulted in lost viewers.
                    Today, 09:46 AM
                  • NC Scroller
                    by NC Scroller
                    I think Kelly did that because I wrote a letter to the editor complaining about an article in the last addition. It was the article about staying connected online and it didn't mention the FC forum....
                    Today, 06:36 AM
                  • hotshot
                    Reply to Demo display
                    by hotshot
                    The fastest I've ever seen one of those 3d deer cuts was by Rick Hutcheson. That man was super fast when we was working the shows.
                    Here he is much more recently, and a bit slower: https://www.youtube.com/watch?v=riPDY6M-Lv8
                    Here is the pattern on Ricks' site: http://www....
                    Yesterday, 10:58 PM
                  • Linda In Phoenix
                    Reply to Woodgrain Worked Against Me
                    by Linda In Phoenix
                    Rodney you and your wife make a great team! Very nicely done sir.
                    Yesterday, 07:08 PM
