best wood for compound figures
  • best wood for compound figures
    I began doing those little compound cut figures you know the reindeer snowman etc xmas ornaments what kind of woods best for that i have tried pine but have settle on my carving wood which is basswood, it might be a bit more expensive but works pretty well, is it cheaper to glue up like 1 x and use that? and do tghety hold together better with a different wood?
    I generally use poplar.
      I use both laminated as well as solid. It depends on wood availability at time I am doing project. I even use different wood species. I do keep my choices of species that are compatible. Hard wood to hardwoods, soft woods to soft woods.
      It becomes a bit more important with pattern placement with the laminated pieces.
      cwmagee
      aka Fibber
      Producer of fancy firewood​
        I think bass wood is too soft as is the soft pine, I like poplar and the harder pines. For really tiny stuff I like cherry. This was cut in pine as you can see it is fuzzy and some antlers are missing. small deer 2.jpg
          I use Ash for the Miniature Birdhouse Ornaments.
          Denny
          ArtCrafters in Dayton, TN
            thank you all
              For the reindeer I use Mahogany because it is soft enough to cut but finishes nicely. For the min birdhouses I use whatever hardwood I have available. Walnut, Cherry, Mahogany, Alder, Maple. I have even used Redheart, Yellowheart and Purpleheart. And some soft woods like Red Cedar and Reddwood.
              Dan in So.Ca.
                Angel 3d.jpgC Horse3.jpgDragon.jpgREINDEER 4.jpg I make 3d cut toys by the hundreds. Reindeer, horses, dragons, swans, and angels. I have tried every wood I could think of and found that , although poplar and basswood work well, sugar pine works best. I do not put any finish on them . I know hardwoods finish much nicer than softwoods do.
                "No PHD, just a DD 214"
                  I use poplar, basswood, butternut and pine. Avoid any knots. They may look cool but often far apart. Pine can be harder to cut then the others because of the pronounced grain which the blade tends to follow.
                    Jim, Is the sugar pine the harder denser grain?
                      No, It is quite soft and sands nicely. It is true, the gain may cause cuts that are not as straight and you can get using other woods, but with diligence I can overcome this problem. I actually cut the long cuts (Front view) with my band saw and the profile with my scroll saw.
                      • leehljp
                        Reply to coronavirus conversation
                        by leehljp
                        From a "Pen" forum:
                        Wife, calling out from another room: "Do you ever get a stabbing pain in your chest, you know, like someone is sticking pins in a Voodoo doll with your image on it?"
                        Me: No, Why?
                        Wife (about 5 seconds later) "How about now...
                        Today, 08:59 PM
                      • Linda In Phoenix
                        Reply to Ice Cream
                        by Linda In Phoenix
                        That's adorable! I haven't received my copy of that issue yet. I think it went slow truck this time. When I do I am going to check that out!
                        Today, 08:28 PM
                      • Linda In Phoenix
                        Reply to Why can I find..
                        by Linda In Phoenix
                        From what issue? This crayon is dull, but I'd like to help look.
                        Today, 08:26 PM
                      • Barb.Enders
                        Summer issue patterns
                        by Barb.Enders
                        It was great to receive the summer issue today as the snow squalls were flying I was very excited to copy to try the fretwork Parrot by Charlie Dearing. I have spiral blades on order and should be receiving them soon as well. Did you mean to cut the last bit of tail off. It looks odd that it has...
                        Today, 06:35 PM
                        Why can I find..
                        the extra balloon pattern from this issue? We know I'm not the brightest crayon in the box, my daughter's words, but I've searched for it on here and scrollersawer.com and nothing. Help!!
                        Today, 12:37 PM
