Elm trees
  • Elm trees
    Three or four years ago some friends had their elm trees cut down. They gave some of the stumps and other pieces to me. Up until a few weeks ago I didn't know what to do with them. It turns out that one my new coworkers knew exactly what to do with them. Her boyfriends parents have two different sized saw mills. They cut most of the stumps into rounds and some into boards for me. They also cut a cedar stump I had into rounds. The smaller saw mill is only about a 20 minute drive from me. Some of the other stumps they took to Rapid City so his parents could cut those on the bigger sawmill for me. To me this was above and beyond since it's a 3 hour drive to Rapid. I've only been working there for a few months. She also told me that the parents left a lot of milled boards at their old farm. I have permission to go out and dig thru them and take what I want free of charge.
    So now my question. Would a FD #5 UR cut thru the elm well enough or do I need a Polar blade. It looks like the boards are between 1/2 to 3/4 inch thick. I've also noted that some of the boards are not easy to sand. Is this common for elm? I'm using a 100 grit to start out with, then 60, then 150. The elm rounds do not have many cracks running towards the center. I think they call it checking. The cedar rounds do have some serious checking. I'm still working on the best way to fill in the cracks.
    When the trees were first cut down I was told the guy doing it would cut them in thinner rounds.His version of thinner rounds was two to three inches thick. I thought about clocks of some sort but I don't have a forstner bit that big yet. If I recall right the bit needs to be 3" in diameter to hold a quartz time piece.
    Lots of questions here. If you are sanding end grain on the slices that will take time and a lot of effort. start with the 60 and work your way up.
    a #5 on 1/2 to 3/4 should be fine.
    Regarding the clock, you can use a hole saw to cut the perimeter and if you are not going all the way through remove the rest with a router or even a chisel. If you are going all the way through then use the hole saw from both sides. A 3" forstner bit will give you the cleanest hole. Just make sure to run it very slow. this chart only goes to 2"
      Elm has always been my favourite wood - but having said that I've found it best used in projects that can show off its very unique grain (both the planed surface and the end grain). It has a couple characteristics that can make it a little challenging and frustrating at times - most notable is that it has a tough and stringy grain - which can make it miserable to sand and machine. I did try to use it with some fretwork patterns a couple times - and don't any more - it takes the curse of the fuzzies to a whole different level. When machining it is good to make sure your tools are sharp - a dull router bit will encourage some serious tear-out and a dull (or the wrong) blade on your table saw or chop saw will make for some painful sanding time to prepare the end grain for a nice finish. Like any wood - you are gonna want to make sure it is dry - but with Elm you will really pay a price if it is not.
      Hears a couple pictures of projects I have used Elm on that turned out quite well.
        Thanks for the answers. I started sanding on the end grains last night and yes it's going to take a while to sand it smooth. But I'll keep at it.
        • Sandy Oaks
          Reply to Welcome Larry
          Sandy Oaks
          Welcome to the forum from TN. You have some amazing projects!
          Today, 09:20 AM
        • meflick
          Reply to Milan Cathedral
          Congratulations and very well deserved. It looks fabulous. Thanks for sharing....
          Today, 08:37 AM
        • meflick
          Hi Larry and welcome to the group. You have an impressive resume and give solid proof that not all good education must be obtained in a college setting. Desire and hard work play a big part no matter the path. Your woodworking is impressive. Thanks for sharing your story and some pictures. I hope...
          Today, 08:36 AM
        • leehljp
          Reply to Something I saw today that my children liked over 35 years ago.
          About 40 years ago, I had about 1/2 inch of my right thumb cut off with a fork lift accident (hand in the wrong place). If anyone asked what happened when my girls (anywhere from age 6 to teenagers) were around, they always replied: " He stuck his thumb up his nose and a bugger bit it off!"...
          Yesterday, 09:49 PM
        • mtwoodguy
          We are very pleased that you have becomea member of the forum! Thank you special for the information you shared with us.
          Floyd in Reno Nv (A one time resident of Lincoln, NE)
          Yesterday, 06:50 PM
