I am scrollsawing on approx. 5/8' cherry and am having trouble with the edges burning. I am using #5 Olson reverse tooth blade. Would a faster, or slower speed help? Or a different size blade? Thanks for help.
Scrollsawing on Cherry
Re: Scrollsawing on Cherry
Hi.I use a #7 reverse tooth blade when I scroll cherry.I usually use a medium speed,but most scrollers have advised me to start high and slowlly decrease the speed until the wood stops smoking.{Try it on unpatterned section for best results}Hope I have been of some help.Good luck
Mark
I use the precision ground blades and that seems to help. But, as previously stated the right speed is the critical part. One thing that might work is lubricating the blade with some of that blade lube. Haven't tried that yet. Butif you get the speed right with an agressive blade, you'll be o.k. anyway (probably).
From a 2012 post I found using this web site's search engine, maybe this is what you are looking for...
https://www.scrollsawvillage.com/for...using-gimp-l1/...-
Yesterday, 12:18 PM -
by shop dogHi everyone...long time, no post.
Last year, i was using a website to generate scrollsaw portraits. I lost the link, and forget the name of the site. If it's permitted here, could someone refresh my memory?
Thanks, Steve-
Yesterday, 11:54 AM -
by RolfPT, as painful as it can be is crucial! I shattered my right elbow in 2003, 5hrs of surgery and lots of hardware put it back together.
The PT brought tears to my eyes many times But I now have a full range of motion. The only thing I can't do is throw stuff like rocks and frisbees my elbow lets...-
Yesterday, 10:37 AM -
