I am scrollsawing on approx. 5/8' cherry and am having trouble with the edges burning. I am using #5 Olson reverse tooth blade. Would a faster, or slower speed help? Or a different size blade? Thanks for help.
Scrollsawing on Cherry
Re: Scrollsawing on Cherry
hi, try putting wide shipping tape onto your wood. It lubricates the blade helping to keep it cooler. Which will help reduce or eleminate the burning. May also need to slow your speed down some. I believe cherry does burn easy, but the tape will help a lot!
I tried Olson PGT blades two different times before I discovered Flying Dutchman blades. First time , I thought I just got some bad ones. Second time was the same.Not at all satisfactory for me. I tried them because I thought they might be better than the regular line of Olson.
Then I tried Flying Dutchman and I'll never go back to another brand as long as they cut the way they do. I have been using FD's exclusively for the last couple years. They are sharper and last longer than any blade I have ever used. I buy them by the gross and my favourite ones are the FD-SR series(Flying Dutchman-Scroll Reverse).
I agree with the clear packing tape for cherry and slower speed. I would use a FD-SR # 5 for that and if the fretwork is not real intricate,I would use a FD-SR # 7
Talk to Mike at the address below and he will give you expert advice on blades and even send you a couple samples.
He's Da Man...
W.Y.
Reply to Harbor Fraughtby RolfI did not read the fine print, actually not that fine. when I went to buy my new compressor for 25% off (not). That would have been nice, but I am still happy with my purchase. Although I have not used it yet as my garage is rather cold.
7 deg this morning 50's tomorrow-
Today, 09:22 AM -
Reply to Harbor Fraughtby JimernSome manufacturers will restrict items for resale to a certain price or basement price. And in some cases will only sell with the agreement of no discounts allowed.
And then there is margin, the retailer needs to make a certain amount of money on all sales.-
Today, 09:20 AM -
by RolfHave you had big temperature swings in the shop? My first thought is something binding. I fix all of my own stuff and don't hesitate to take things apart to try and isolate where the issue is.
That said at only two years old I would contact Denny and see if he can direct you to a Pegas tech center....-
Today, 09:15 AM -
by NC ScrollerWelcome. Could be a number of things. I would call Denny at Art Crafters of Dayton or Ray at Seyco. Both numbers can be found on the internet.
Today, 06:47 AM -
