best online store in uk for wood ?
  • best online store in uk for wood ?
    Hi ,
    I was just wondering Does anyone get wood online ? and if so best uk online store you have found for birch faced ply etc. I cant find any locally available so any suggestions of uk stockist etc would be much appreciated.
    thanks
    Adam
    I haven't used them but SL Hardwoods - www.slhardwoods.co.uk/default.asp - are offering a Russian birch plywood which could well be OK. Also they do a range of veneered ply for some pretty effects as well as a range of hardwood timber. And most importantly they do deliveries UK-wide.
    Chris
    Saws: AWSF18, Meccano Mk II
      Thanks for that link Chris looks a good source of veneered ply..One thing I was thinking was does veneer cause any problems while sawing like it lifting etc ???
      Adam
        Rolf,
        Are you ok Rolf?
        Today, 05:43 PM
      • Jim McDonald
        by Jim McDonald
        Today, 09:10 AM
        Today, 07:43 AM
      • evilbadger
        by evilbadger
        Today, 06:40 AM
        Yesterday, 08:41 PM
