Isn't 4" wide hardwood suppose to be 4 inches? I was getting ready to cut a few coasters and when when putting my pattern up against the maple, it didn't look right. My pattern with margin measures 4" but the board was a bit narrower. I measured the board and it's only 3 1/2". I picked up 2 of these 2 foot long maple boards locally yesterday and they are marked 4".
Hardwood Measurements
Tags: None
I think you got caught by the nominal hardwood measurements!
It probably was 4" when rough-sawn. After planing and joining, the wood ends up around 3 3/4" t- 3 1/2"
BOb -
A 4" used to be a 4" back in the days when a cord of wood was 4x4x8. Nowdays prices are up and measurements are down.
No measurement is what it says. All of it is a bit smaller. I always go in with my measuring tape to be sure that I get what I need.Dragon
Owner of a nice 21" Excalibur
Owner of a Dewalt 788
PuffityDragon on AFSPComment
Whenever I buy wood from Sloan's, it's always the width I order. I just measured a couple pieces from them and 6" is exactly 6". Leave it to a local retailer to screw me over.Comment
Hey Dragon.
When I lived in Ontario a cord was considered 4' x 8' x 16" and classified as a face cord
Out west here where I live a cord is 4' x 4' x 8' and is called a box or a bush cord. It's like three face cords in one.
W.Y.
Here is one of pine and larch.
and two of white birch with real good measure because it is 4' wide x 4' high at the ends and 16 feet long. But it is rounded up to over 5' high in the center.
Delta P-20 Scroll Saw, 14" x 43" Craftex Wood Lathe and Jet 10" Mini Lathe .Comment
Sloans is different than nominal lumber. Sloans is not selling 1x6's , they are selling 6" wide boards and by a specific thickness too.
The 1 and the 6 such as when you go to a normal lumber store is exactly like Bob says it is. It is milled at the saw one inch think and 6 inches wide...when it dries it shrinks a bit, and then it is planed to clean it up and straight edged, where it ends up at 3/4 thick and 5 1/2 wide. or possibly only 5 1/4 wide !
Think wendy's ...the 1/4 pounder weighs a 1/4 pound before it is cooked.Jeff PowellComment
And a Big Mac
When ordering wood, finished (milled) wood is smaller as explained previously
Rough wood, be it softwood or hardwood, is mesured in quarters (4/4, 5/4, 12/4 (pronounced four quarter, five quarter, twelve quarter) ) when refering to thickness, so if you want to end up with 1" thick wood when planed both sides you're better off getting 5/4 rough wood to start with.
As for the width it varies, but note that rough wood is priced and measured in board feet (equivalent to 1" x 12"x 12") = thickness x width x length (measured in inches / 144)
so a piece that is 12/4, 6" wide and 6' in length is ( (3x6x72)/144) or 9 board feet.
and a piece that is 4/4 x 12" wide x 9' long is ((1x12x108)/144) also 9 board feet.
Regards,
Marcel
Edit : changed the term linear feet for board feet (translation confusion: French term is pieds planche lineaire, translates as linear board feet)Last edited by Marcel in Longueuil; 02-02-2007, 08:37 AM.http://marleb.com
NOTE: No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.Comment
Bill
A cord around here is 4' x 8' x whatever length the wood is cut to. So it is usually 16" but can be 18" or 14". And the price is between $90 to $100 for that little.Dragon
I guess I assumed since it's a "hobby board", the measurements would be exact. At least the thickness is what the label reads.Comment
I agree with you Mike. Take em back........"Orphans are easier to ignore before you know their names. They're easier to ignore before you see their faces. It's easier to pretend they're not real before you hold them in your arms. But once you do, everything changes."
D. PlattComment
Gill, all I can say is SHAME ON YOU!Comment
you have to watch the thickness...
your right about 3/4 isn't always 3/4....I've bought 3/4 walnut, cherry and other hardwoods from different sources and a lot of times they don't match up..
I've learned, if I run out of wood on a project....go back to the same place you bought the original wood from...
TroutHawk G-4 Jetcraft
Fish are food, not friends!Comment
http://marleb.com
Reply to About ornament exchangeby Jim McDonaldDave, I will participate. Thanks for doing this again.
Yesterday, 09:10 AM -
Reply to Testing this blower motorby RolfWithout the complete schematic it is hard to know what is correct.
That said, it is a multispeed blower that obviously has a controller board. That board varies the power to the motor. By doing what you did you bypassed that. You put power across the low and high windings. If any thing connecting...-
Yesterday, 07:43 AM -
Reply to Testing this blower motorby evilbadgerIf he connected to red and black and the motor spun wouldn't that indicate the motor is grounded? Without connecting the white the circuit isn't complete and the motor should not spin.
Yesterday, 06:40 AM -
Reply to Testing this blower motorby cwmageeThe reason for the smoke is incorrect wiring, posible melted insulation between motor windings and motor frame.
You mentioned connecting power to the red & and black wire. Did you do anything with White wire? Per the lable on the motor the black wire is high the Red is low. White common...-
09-28-2023, 08:41 PM -
