plexiglass
  • plexiglass
    how do you cut plexiglass? when i cut it, it melts back together. it is frusterating!
    thanks
    "You should see what I saw!"
    Making sawdust with a Delta SS350
    its blade choice. I use Flying dutchman polar blades with great results. The tooth configuration is designed for cutting plexi. Dale
      Slow down your blade speed and your feed rate. Also, try using skip tooth blades with no reverse teeth.
      DeWalt DW788 & Dremel 1680
        thanks! ill try it!
          Just plain skiptooth blades will work fine. I cut a bunch of ornaments with them and had no problems at all. I had great luck with Pegas #3 skiptooth. As mentioned, slow down the saw and the feed rate. Also, make sure you don't remove the paper from the plexi before cutting. If the paper is missing on one side, replace it with tape. I also use black plexiglass for the backers for all my portraits and never have a problem with skiptooth blades.
          Mike
            Try here:
            Click on video tips, then scroll down to plexiglass. The tip using mineral oil is the best.
              Scrollerman:
              I have cut a lot of plexglass (the 1/16 inch thick type) for patterns and yes it would stick together due to the heat of the blade melting the plexi. What I found works for me is to place a single strip of 2 inch packing tape (the kind for keeping cardboard boxes shut) on the underside of the plexi behind the cut line. I find a standard 12 TPI blade works best. Hope it works for you.
              Scrolling satisfies the passion for intricate creativity. My saw is an Excalibur EX21.
              • Linda In Phoenix
                Reply to New Here
                by Linda In Phoenix
                Hey new person! Arizona here looking forward to seeing some of the things you do. Ask questions and share your insights along the learning curve. We like brainstorms....
                Today, 10:03 PM
              • KarlB
                Reply to Production work
                by KarlB
                Steve,
                Karl...
                Today, 09:15 PM
              • Jim McDonald
                Reply to New Here
                by Jim McDonald
                Greetings from central Indiana. Most of the good stuff I know about scrolling, I learned here. The rest was from fixing mistakes or doing stuff again because I didn't pay attention to what I read here.
                So, ask your questions and post your photos.
                We're here to help. Nobody keeps any secret...
                Today, 05:39 PM
              • wjbclocks1
                Reply to New Here
                by wjbclocks1
                Welcome ,we like pitchers, and don't be afraid to ask Questions. there are no suck things dumb questions .we all learn from them...
                Today, 04:32 PM
              • NC Scroller
                Reply to New Here
                by NC Scroller
                Welcome from North Carolina. 👋
                Today, 01:18 PM
