Plywood question
  • Plywood question
    I've recently purchased the Victorian Sleigh plan from Wildwood Designs, and I plan on making this out of 1/4 inch plywood.
    I've never used 1/4 inch plywood for a fret work project.  Can anybody help me with any advice or what to look for when choosing the wood?  Does the thinner plywood have gaps throughout the wood like the thicker stock does?  OR...is there a better wood I should look into?
    There is a Rockler's near me and the guys there are great.  However, any additional help would be greatly appreciated.
    Thanks!
    Re: Plywood question
    I would look for marine grade plywood, it's scanned for voids and 'repaired' before it's sent from the factory.
    Also use a slow feed, plywood is known to chip easily and isn't my choice for any type of delicate scrolling!
      Hi, I agree with the marine plywood. I tried hardwood plywood, thinking that it would be better because it cost more. No way. Tried birch and oak, and had serious problems using both. Softwood seemed to work better. Have you thought about planing pine or cedar down to the desired thickness. Or even buying cedar or pine wainscotting. Its thin and might fill the bill. I'm not really prone to using plywood. :-[
        Personally I would not choose plywood to do any scrollsawed project that is designed for indoor use. But being that said you want to use either Baltic birch plywood or Finnish birch plywood. You want plywood with a finnish side on both sides because they are both going to show. I have in the past used oak plywood 1/4' with a finish side on both sides but that gets expensive so I use hard woods instead. The baltic birch will take a stain but you will want to use a stain conditioner when staining to prevent blotching. Good luck!
        John T.
          Thanks for the feedback. I've decided to stay away from plywood. It only makes sense that if I'm going to put that kind of time and effort into a project, I don't want to have to worry about chipping, etc.
          Thanks again!
            I have used both solid wood and plywood for many projects. Each year for Ash Wednesday I create and cut 300 small crosses out of 1/4 inch plywood and mount a magnet on the back so it can be placed on the refrigerator door. Depending on the plywood, either black walnut or oak I stack cut 4 or 5 at a time. The tearout is so minor that you can`t notice it. The secret is to use a quality blade, all I use are Precision Ground Olson Blades. A lot of success is dependent on your rate of feed.
              The best blade for cutting any plywood is the fd two way cut blade.
              Last longer and about half the price.
              Morly
                I agree with Morly about the Flying Dutcman blades . My choice is the FD-SR ones. Way way less money and a lot better sharper and cleaner cutting blade and of course they last longer as well.
                Sparky.
                • NC Scroller
                  by NC Scroller
                  I often resize just to fit the size of the wood I have on hand. I agree this is a no win situation because of the various software, hardware differences plus the skill level of us, the end users. Even providing the patterns in a digitized format will no fix this because of the reasons I already mentioned....
                  Today, 09:52 AM
                  John your original post is a valid question. It is a simple thing to put in the original scale assuming that it was on the original drawing. As a minimum the size of the material required can be stated, although that has been a confusion for folks that have built the clock projects. I field a lot of...
                  Today, 09:22 AM
                • Quartz43
                  by Quartz43
                  Maybe nothing has changed ? But is there anything that can be done to make it easier. The very large projects are difficult to copy over several pages and put together properly. I believe in making improvements and not preserving the status quo.
                  I enjoy the challenge of cutting a project...
                  Yesterday, 08:48 PM
                • keystonecop
                  by keystonecop
                  This is not a problem with the magazine for my issue.. It is a problem with the book having resized the drawings without giving the actual size.
                  I do again apologize for my post.. I cannot use the right words to explain it.. so maybe someone should just remove the post....
                  Yesterday, 07:29 PM
                • markdavd
                  by markdavd
                  Reading these replies, I am still trying to figure out what the problem really is. I haven't noticed changes in how they publish recently and I don't think I ever had trouble making copies of of the patterns I want to cut.
                  How did you copy the patterns 10 years ago? What has changed?...
                  Yesterday, 06:43 PM
