wood from new place
I think I hate you Tim, LOLMay the wind at you back .....
Not be from Lunch.
Oily's Gallery
I just might have to go along with Oily on this one!
What do you plan to do with all of this wood?Rolf
@ oily and rolf…it’s ok to hate me, i’ll still like ya….lol…[email protected] rolf…right now i’m just gonna use it to make blanks for compound projects (diana’s birdhouses, and Christmas ornaments), that is, until i get the new tires on the rikon…i’ve owned that danged bandsaw for almost 2 years now, used it 3 times, top tire flew off about 8 months or so ago, been down ever since….ain’t had no good luck with that saw…pouts…@ hammer….maybe a lil of both…haha….and i wouldn’t have a clue as to what it is actually worth….i know i’ve got $200 in it for having the logs cut into the planks you [email protected] CJoZ and mtnman…not quite sure you could afford the shippping rates? mtnman, not gonna burn it, no reason to, so i guess i’ll just make some stuff
Get the urethane tires from Carter
no glue to mess withRolf
Oh rats Tim, now you are just rubbing it in...............sign it's not fair sign.gifGloria ............... Two memorable things to say in life, "Hello" for the first time, and "Good-bye" for the last.
Today, 10:23 AM -
Today, 10:19 AM -
Today, 07:55 AM -
Yesterday, 08:15 PM -
Yesterday, 05:07 PM -
