I have bought some walnut and sycamore (just less than 2 inches thick) to make the pieces for my new chess project. Will I be able to cope with such thick wood, and please can you tell me which type of blade I need to use.
Sycamore and Walnut?
That will depend upon the clearance on your particular saw. if it will accept that thickness you can cut it. I would use no less than a #7 blade and probably not a reverse tooth blade. You will really need to keep your feed rate slow, let the blade dictate the speed of your cut, do not make it bow or you will not be pleased with the outcome.
I watched your video (Eiffel tower cutting), so i see you already have the patience thing down.....<smile>Last edited by wood-n-things; 12-28-2011, 01:01 PM."Still Montana Mike"
2" thick is stretching the max capacity of most scroll saws. Neither sycamore nor walnut are especially hard, so as long as it fits within your saw, cutting it shouldn't be too much of a problem. As Mike said, a larger blade would be called for, perhaps a skip tooth. The size will depend on how tight the turns are in the patterns. Use the largest with which you can readily navigate the pattern. Skip tooth blades have larger spaces between the teeth, for better chip clearance, which reduces friction and heat build up and helps extend blade life.
Feed rate is basically how hard/fast you are pushing the wood into the blade. This is different from blade speed, which is dictated by the speed control setting on the saw.Homer : "Oh, and how is education supposed to make me feel smarter. Besides, every time I learn something new, it pushes some old stuff out of my brain."
Thanks for helping out Bill. I've been preoccupied with research today."Still Montana Mike"
The thickest I cut was 1 1/2" cherry or walnut, and used a 7 or 9 skip tooth blade. Worked great.Betty
Reply to I need your insightby Gary beasleyI know another scroller who makes 3d toy items for the kids during demos as well.
Today, 07:31 PM -
Reply to I need your insightI demo at our county and state fair every year. People love seeing a variety of items from each of the areas (fret, intarsia, segmentation, etc.). I have my saw there, a small drill press, and some wood to demo with. I also take along a few issues of the magazine to encourage others to get into the...
Today, 06:45 PM -
by millwabI'm not sure where the best place to post this would be, but it made sense to me to start here. I'm starting to plan for my first (ever) scrolling demo at our county fair this year. Besides the saw to show how cutting is done I want to have a display of sorts that people walking by could view. My...
Today, 04:19 PM -
Reply to More Miniature Birdhouse Ornamentsby NC ScrollerI love cutting those. Nice job.Today, 01:24 PM
