Curly Lychee
  • Curly Lychee
    The lumber store had a piece of Curly Lychee and a piece of Iroko when I stopped in there the other day. Since I haven't had the opportunity to have either piece before - I naturally bought them and figured I would find something to use them for. Figured I would whip out a couple of "quick" Treble Clef Clocks. Ha!
    That Lychee makes cutting oak seem like running a hot knife through warm butter. Granted these are both rather thick pieces - the Lychee is 1&1/8", the Iroko is 1". Needless to say - my "quick" clocks turned into a much more time consuming project than I normally spend on them.
    Couple questions.
    1) I wound up using some #9 Olson PGT blades - took 4 blades to cut 2 clocks from that Lychee. The Iroko cut fairly easily and used my normal FD #9 SR. I haven't used the skip tooth blades before and was wondering if that may be helpful in very hard and thick woods. Any thoughts on blades for thick and hard woods?
    2) Neither wood took real well to my normal finishing, which is a shot of Deft spray lacquer. I've run into this problem with a few other woods as well - Murado (Rosewood) is the one most recent. The lacquer starts running off the wood as soon as you start shaking the can prior to even spraying it!
    So - recommendations on blades for very hard and thick woods and finishing techniques on those woods that just don't like spray lacquer.
    Thanks...
    Douglas Fraser
    Eagle River, Alaska
    My Gallery - Aurora Wood Crafts
    Douglas I use Lychee from time to time and I finish it with MinWax Poly....I use foam brushes to apply it. I think I use #7 or 9 blades as well for cutting....pretty hard stuff isn't it.
    Hawaiilad
    Larry
      I was cutting bowls from 1.25" Big Leaf Maple and found that #5 FD Polar (skip tooth) cut a lot better than #9 FD UR. Not all that hard but thick and need to clear out the cuttings.
      Terry
      Got Moose?
        Reply to I decided I needed a challenge
        Interesting, I will nee to try that.
        Today, 08:01 AM
      • handibunny
        by handibunny
        Back in my days of collecting antique pottery, I used to carry a a small blacklight unit to check for repairs that were invisible to the naked eye. I never knew that it could detect glue spots. That's a lot neater than using mineral spirits, or waiting until a sealer coat of shellac reveals missed...
        Today, 06:22 AM
        Reply to My lucky day!
        Being a diet controlled type 2 diabetic, I check my glucose. Checked before my shot on Tuesday it was fine. Checked on Wednesday after a morning walk expecting to see less than 100 and about fainted when it read 158. Every check has been 150 or more since then. Started reading and yes, the shots can...
        Yesterday, 10:37 PM
        Not yet Jim. The corners of the baskets to appear to be drawn by hand or just a bad copy. The price might go up. Thanks Linda. For some reason I really like doing layered baskets. And my customers like buying them. Bruce read a blacklight shows glue spots. Guess what he bought me from harbor freight...
        Yesterday, 10:04 PM
      • handibunny
        Reply to Need advice...
        by handibunny
        Jim, if all else fails, try this link://birchbarkstore.com/collections/tree-slices-log-rounds-slabs-tree-stumps
        I've bought lovely aspen and Balm of Gilead rounds from this site to use for live edge bowls. The owner, Rene Guay (pronounced "Rainey") could probably fabricate something...
        Yesterday, 03:38 PM
