hello guys ,
i am making a segmentation project (like neal moore's) using softwood (pine) and after i stained the wood i found that if i pressed on the wood with my finger nails , this leaves marks that affect the color of the stain.
my question is if i apply a sealer , will it provide a protective coat on the wood ?
i need the finish to be satin or semi gloss ... or will the varnish give that protective layer?if yes .. will the varnish give that coat without applying sealer before it ?
thanks
thanks
