I have a parkay venneer over particleboard table top. Since I have not started a project yet, I did not know if this wood is usable.
Any advise is certainly welcome
woodman44, were you planning to use it as a backer or cutting a picture out of it? How thick is it? Cutting a scenic picture or portrait most of us use 1/8", 1/4", 3/8" or 1/2". I would try to cut it first. Wood with a lot of glue in it will dull your blades faster.
Mick, - Delta P-20
I wonder if warping would be a problem with only one side vennered. Seems it woud absorb moisture at different rates. Then again finish on both sides would keep that to a minimum.
Try it, you may like it.
I've cut waferboard for a few projects. The glue dulls the blades faster, but it gave me the 'look' I wanted. Blades aren't that expensive.
Political correctness is always political and rarely correct!
Hi woodman - I would think that particle board will not be too sucessful a material. As has been mentioned, the board contains a lot of glue and also dependent on the quality of the board it can contain a lot of inert 'rubbish'. I've found that particle board in Mexico for example regularly contains small stones and even metal turnings! In general the material will quickly blunt new blades. Particle board also tends to crumble easily especially from the centre of the thickness where the material is usually less compact.
For cutting puzzles where the peices are liable to get a lot of handling I would think that it would soon start to break up. But, as has been suggested, give it try and assess your results.
Jim in Mexico
- Albert Einstein
I personaly would not use it for a real project. The veneer is very thin so sanding it is risky. With the exposed edges it would not appeal to me.
SLRA does a “spot” check. He’s lucky I’m keeping him around. It was free with a purchase at harbor freight. When people pick up a basket to examine, usually first time customers, they inspect everything for glue ups, drill holes, etc. of course, I don’t think half of them know what they are...
Back in my days of collecting antique pottery, I used to carry a a small blacklight unit to check for repairs that were invisible to the naked eye. I never knew that it could detect glue spots. That's a lot neater than using mineral spirits, or waiting until a sealer coat of shellac reveals missed...
Being a diet controlled type 2 diabetic, I check my glucose. Checked before my shot on Tuesday it was fine. Checked on Wednesday after a morning walk expecting to see less than 100 and about fainted when it read 158. Every check has been 150 or more since then. Started reading and yes, the shots can...
