I read about several people using the sticky dots that are used for scrapbooking to help hold wood for stack cutting. I picked up some of these and was going to try them for some ornaments. I placed 5 dots on a 5" X 5" piece of BB ply (one in each corner and one in the middle) and stacked them 4 high. I then placed the pattern on the top and headed over to the drill press. While drilling holes I noticed that the boards would tend to shift side to side a bit as I moved the stack for each hole to be drilled. If it was moving that much and I was just sliding them over my drill press table, I could imagine the amount of movement I would get on my scrollsaw. I decided to put painters tape around the edges before going any further. I did notice that it was quite a bit easier to apply the tape with the dots holding the boards together, so there was one benifit.
For those of you who use sticky dots for stack cutting, what are you doing that I am not? Maybe I just need to use more dots next time. Or maybe stacking 4 hight was too much. Any help with this would be great because using dots seems so much easier than taping it all up everytime.
