Hello, Is there any precautions to take cutting padauk, other than using a dust mask. I was cutting some the other day, (a very small amount) and the next thing I knew I ended up with a headache. It probally was just a coincidence.Any suggestions? Bob.
Padauk
I do hardwood flooring and have recently had the same issue. Have never had a problem with Austrailian Cypress before (have installed over 25,000 square feet+) and a couple weeks ago had a severe headache for a few days. Got away from floor and when came back to sand it, same thing. I have been doing this for over 23 years. Another wood I just had problems with is Trestlewood (reclaimed fir that was sunk into Salt Lake for a time). When cut it smells like a litter box. Won't burn very well either. Very high mineral count which gives it a high moisture reading (17-18%). I will see how I handle the purpleheart project I have to do next week."All it Takes For the Forces of EVIL to Rule Is For Enough GOOD People To DO NOTHING!"
Ive not had any reaction to padauk, or any wood dust at all yet for that matter, except I do notice when cutting cedar my nose seems to get full of snot. I never liked the smell of cedar, even back when I had snakes for pets and raised over 100 mice and rats to feed the snakes,I used pine bedding because I just didnt care for cedar smell, but the dust from it doesnt seem to bother me.
Finishing on the padauk however, I have had trouble with. I used a BLO and MS 50/50 mix, and it took literally weeks to dry. I guess there was to much oil in the wood.I since cut somthing from padauk, and wiped it down with MS prior to coating it with danish oil, and it dried fine.Dale w/ yella saws
Bob,
I love padauk. I've used it for both scrolling and non-scrolling projects. The only problem is that the dust gets into everything! You must have good dust collection. I don't think a dust mask will be sufficient unless it is a very good one. I've never been bothered by the dust, but I know that some people are. My only problem is that it turns my white hair orange!
If the headaches continue I would strongly encourage you to give it up. If you're looking for a red wood try bloodwood. It's harder than padauk, but it's a nice wood to work with.
Dan
Interesting comments. Now where would I get bloodwood from? The woodcrafters store that I go to does not have it.
Carl...As far as the headaches, does the sports drinks really work for you?
My son an I are always plagued with these headaches,that sometime last for days.(don't know what triggers them, and doctors don't either). I had heard of a headache ointment, but could not find it. It goes to say we are always looking for some cure or even pardon the expression an old wives tale of an idea to have them go away. Will try your tip.Thanks to all.BobBe the good,
try www.thinboards.com i think he has bloodwood. Im not sure is www.sloanswoodshop.com carries bloodwood.Dale w/ yella saws
Reply to Darkening oakby hotshotI've had very good luck using the oven. The wood does soften, but with oak, that usually isn't a problem. It also darkens all the way through.
He is a flash from the past where I show some puzzle boxes made with oven darkened oak.
https://forum.scrollsawer.com/forum/...2-...-
Today, 12:32 AM -
Reply to Spiral Blades - Tips & Tricks?Thanks for the post. I have tried spirals in the past and had lots of issues. I need to set down one day and keep cutting with them until I get the hang of it. Part of my problem may have been covered by your number 7. Tried pine thinking it would be easy to cut but now realize the grain may have...
Yesterday, 07:05 PM -
Reply to Eagleby Sandy OaksI agree, a beautiful piece and wonderful cutting. Years ago, my father had Alzheimer. The last six months we had him in the VA center in St. Cloud MN. His wood work shop is still in MN. I could not take it down to TN....
Yesterday, 12:00 PM -
Yesterday, 09:16 AM -
Yesterday, 05:27 AM -
