Shorts
  • Shorts
    Is there a defenitive description for lumber shorts?
    Be the good,
    Are you referring to lumberhosen, the favorite party outfit for German lumberjacks?
      ROFLMAO....too funny. I am just jealous I didnt come up with it first.
        I'm trying to work out what this topic is about.
        Gill
          At Wall Lumber:
          http://www.walllumber.com/sho.asp
          "Sizes range 22" - 56" Long, 3" - 9" Wide."
          So if you are buying from them, that is the definition.
          -Andy
            Gill,
            I'll leave the figuring to you on this subject it's so................. I can't possibly
            decribe it.
            Bill
            Delta P-20
              So.o.o.o--
              If they are pieces of horsechestnut, are they jockey shorts?
              Short-nosed pieces of dogwood - boxer shorts?
              Ah - well...
              Sandy
                You folks are bad.........but funny.......
                Lonepine - I think you'll find that lumber shorts are simply pieces of wood that are shorter than industry standards for the intended uses.
                I'd hate to hear what these folks would call a short piece of cherry........
                D. Platt
                  Gill,
                  Those guys don't look like lumberjacks to me!!
                  Dan
                  • tgiro01
                    Old Tool - Reborn
                    by tgiro01
                    With all these new tool stories, I was working on and old one. About 9 years ago, I built a router table. Then, before it was finished, I had to start using it. And I have used it over the years. A couple of months ago, While I was contemplating cleaning, I looked at the machine and decided to finish...
                    Today, 03:24 PM
                    I do remember that 2011 Wow, you were gutsy building that then, CNC was just coming into the home environment. Are you still using the one you built?
                    Today, 10:23 AM
                    Jim that is why there are now CD's available for past issues. To me a copier/scanner and printer are a necessary part of my tool inventory. JMO...
                    Today, 10:19 AM
                  • Jimern
                    by Jimern
                    I dropped my subscription long ago, so maybe I should not chime in, but I dropped it mostly due to the pattern pull out.
                    But the result is that if I cut a pattern to scan, I have also cut the parts of...
                    Today, 07:55 AM
                  • Quartz43
                    by Quartz43
                    +1 on NC Scroller's suggestions. I would add that on appropriate patterns stop using the grey as it would make it easier to copy.
                    It says a lot if Fox Publishing does not comment on an issue like this. Even if they said they are aware that people have concerns and are looking into it...
                    Yesterday, 08:15 PM
