What wood should I use for a first project and some there after?
? wood/ first project
I think you would be best to start off using a soft wood such as pine or poplar. If you have it handy or can get it easy enough I would use something 3/8 to 1/2 inch thick. For first projects I would pick up a copy of John Nelson's book "Scroll Saw Workbook". If you take it setp my step you will be a master in no time. Good Luck and Happy Scrolling.
ScottScott
I personally don't like pine for scrolling- I am afraid if you use that to learn you will get discouraged in a hurry- pine doesnt scroll well at all for me - it breaks to easy- I use baltic birch plywood i get from home depot- a 1/4 inch sheet is $ 20--1/2 inch is $30- for a 4 x 8 sheet and they will cut it down for you . just be sure to store it flat and away from drafts - including heat vents
I have a sheet cut into 6 pieces and that way i can have big projects in a same grain line and then cut the size I need for smaller one myself
Sharon
As we scroll we learn more and more about the materials we use.
I started by using some cheap plywood paneling that splintered like crazy.
Then I tried MDF, sawdust like crazy, but it is a consistent product that allows for consistent cuts
I have used pine but it is best to get close grained stuff, the dark rings can slow down the blade and the softer pith can let it cut fast.
I do like using it for some segmentation projects because I can incorporate the grain into the project. It is also very easy to sand.
I do like Baltic birch ply for fretwork and for jigs and boxes.
I also like hardwoods for the same things, but the grain has to be just right or it is a waste of good money.
It is hard to give a definitive answer if we do not know what you want to make.
I look back now at some of my first projects and think of how much better they would have been if I had used the best material for the project.
So let us know what you would like to scroll and we can help.CAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
Yesterday, 08:15 PM -
Yesterday, 05:07 PM -
Reply to What is it?by meflickBoredom has probably lead to many a great idea, invention, etc. throughout life. I too like this concept of mixer pieces storage.
Yesterday, 04:03 PM -
by markdavdThere are a lot of good points brought up here. Some may be easy to correct, others not so much. As far as Fox Chapel replying to this thread, I am trying to imagine a response that would not have made at least some people upset.
As far as the pattern size in the books, I believe the physical...-
Yesterday, 03:23 PM -
Yesterday, 09:52 AM -
