Another question? Can anyone give me an Idea about the projects where I would use 1/8" verses using 1/4" I've just been messing around for a a couple of weeks and am ready to do some easy projects like silloutes and perhaps some small puzzles. I'd also appreciate it if you might mention some other projects you've done and the type of wood / thickness you've used.
When do use 1/8" vs 1/4"
I use 1/8 hardwoods for ornaments and for pieces mounted on a hardwood plaque. I'll use 1/8-5/8 for pieces mounted in a shadowbox frame. !/8 ply makes excellent backer boards as is great for detailed portraits."Orphans are easier to ignore before you know their names. They're easier to ignore before you see their faces. It's easier to pretend they're not real before you hold them in your arms. But once you do, everything changes."
D. Platt
I use 1/8th plywood or hard wood for backing on my potraits and for overlays on certain shelv's an clocks. I like the look of 1/8 for xmas ornaments alot more lacy an delicate. easyer to cut in a stack for fragile work. look at the jennefer clock , it has 1/8 pieces on the sides. very beautiful.Last edited by minowevie; 01-21-2006, 09:31 PM.
harrisg, I use 1/8" Finnish birch plywood for all my portraits and scenery pictures with 1/8" luan plywood for the backboard. I use 1/8" solid mahogany, cherry, walnut and red oak for cutting butterflies. Mick.Last edited by Mick Walker; 12-11-2005, 12:11 PM.Mick, - Delta P-20
I use 1/8 for silouettes, portraits, overlays, inlays, ornaments, filler strips on boxes and tons of other stuff. I use 1/4 for silouettes, portraits, overlays, inlays, ornaments, filler strips on boxes and tons of other stuff. Hmmm, come to think of it, I use them pretty much interchangeably, hehehe. The additional items that I'll use 1/4 on are boxes, small shelves, business card holders and clock faces. Most of my mini-clocks are cut from 3/8 to 1/2 and tambour style clocks I cut from 3/4.
I know, more info than you wanted, but I'm killing time at work. LOL.
KevinKevin
Scrollsaw Patterns Online
Reply to What do you think?For something like a table saw the volume of air moved is much more important than whether a good vacuum is produced....
Today, 08:57 PM -
Reply to My lucky day!Get my second shot in less than two weeks. Can't wait.
Today, 08:32 PM -
Reply to What do you think?Agree with Scott that it will not be large enough for a saw but would work ok with smaller pieces of equipment.
Today, 08:29 PM -
Try the forum search engine wording it a few different ways. Maybe something will ring a bell.
Today, 07:04 PM -
Reply to What do you think?You scored a working central vac for free....awesome!!
Today, 07:03 PM -
