Grain Direction
  • Grain Direction
    There is a little girl in my church and she loves horses so I decided to scroll the “Rearing Unicorn” from Issue #18 on page 26 for her. I’ve got an old beat up Maple table that I have cut on over the years and have taken out the right size for the Unicorn (actually I will take off the horn and just make it a ‘Rearing Stallion'). The wood has some nice tight grain; my question is which way best should I have the grain flow? Straight up and down or at an angle in the direction the horse is rearing? Thanks everyone!
    Grain direction of a project sometimes comes down to a matter of taste but the general rule is run the grain in the direction the longest side is. If the piece is longer length wise run the grain lengthwise and if longer height wise then run grain north and south. In the case of the horse I would run the grain east and west. Like the direction the main goes.
    John T.
      As a horse owner I have done a couple of projects of rearing horses and I tried to use the grain with the bend of the animal, as I would see it. It all boils down to personal taste.
      Todd
      Hawk G4, Dremel 1800
      Quando Omni Flunkus Moritati
        Okay, you both told me it comes down to 'taste.' What if I don't have any?
          Well you did mention it was for a young lady, so I would go with her opinion as it is the only one that really matters.
          Never second guess a lady even the young ones.
          Todd
            grain direction
            If you are making the copy yourself, try making it on a transparency. This allows you to see the final project before cutting a thing. The transparency allows you to move the image around and be able to utilize the grain as if it were part of the pattern.
              Hi Grizz,
              Look at this picture, you can see how the grain is going. This was a best seller at craft shows with kids who had horses.
              Mike M
              SD Mike
                Grizz
                If you have no taste then how do you know what you are eating. Don't believe everything you read on labels.
                John T.
                  Go with the grain
                  Grizz:
                  IMHO;
                  set the grain to flow from shoulders to tail, and if grain is not straight then add neck to belly. The object is to simulate muscles under the skin. If your wood has the swirl of a grain direction changing, place this on the rear hind quarters.
                  Just remember, unlike an Ox, horses and mules have their power in the hind quarters and the front legs are for steering. A Bull, Ox, or steer has his most powerful muscles in the front legs and shoulders. You get the most work done by using the correct harnes.
                  Phil
                    Grizz,
                    I may have a bit different view of grain - I started out as a carver (and I still am, in addition to a bit of scrolling). I've had so many pieces break off a mouse with cross-grain in the tail that I had to name him Elmer for all the glue I used.
                    So... I'd run the grain lengthwise across the skinniest (weakest) bits of the pattern - probably do the best I could to get most of the legs with the grain rather than across. However, I've noticed that a lot of scrollers seem to ignore grain as it relates to strength, and scroll whatever looks purty. I guess that will be OK if the piece isn't handled very much. For a young lady, I'd go for strength.
                    (of course, this is all just opinion)
                    Sandy
                      Thanks
                      Thanks everyone... now we are getting somewhere! Alot of good ideas floating around. That is what I needed. Now to make a decision....
                        Thanks Everyone
                        I decide to have the grain go at an angle in the direction the horse is rearing. Turned out pretty good. I had the little girl in my office today, I gave her the box with the horse undone. Told her if she could put it together she gets to keep it. She was so cute! She could tell it was a horse and got so excited she was shaking when trying to put the puzzle together. She finally got it..
                        That was fun! and wel worth the time spent on the saw!!!!!
                        • Linda In Phoenix
                          Reply to My computer issues.
                          by Linda In Phoenix
                          I upgraded back in early winter. I got one with both a solid state as well as hard drive. I couldn't move over my Office 2010 because I'd bought it as a download (which was still functioning just fine for what I used it for) and I never switched it to subscription because of the cost. The old download...
                          Today, 12:39 PM
                          New turning tools
                          I just picked up a couple of new heavy handled bowl gauges. 1/2 inch and 3/8 inch from two friends that have tool supply businesses.
                          Our next Scroll saw club challenge will be segmented scroll saw bowls. I don't sand my bowls, too time consuming, so I will be turning them after glue up.
                          Today, 08:04 AM
                          One problem with upgrading was that many of the programs I use are now subscription based. That really frosts my butt I finally accepted the fact that I normally renew my software frequently anyway the cost difference is negligible.
                          I did not go with a solid state drive, probably...
                          Today, 07:58 AM
                          Actually, I think mine is more than 10 years old. And what brand would that be? Remember who you’re talking to here about computers.
                          Today, 07:49 AM
                        • NC Scroller
                          by NC Scroller
                          If you buy a new computer you want to get a solid state hard drive. No moving parts to break or wear out....
                          Today, 07:43 AM
