I never see anything written about using cedar wood for scrolling. It is fairly cheap and smells great, although you lose some wood through knots. It is fairly easy to work with, although dusty. Does anyone else like to use it, or is there something about cedar that I don't know about
Cedar Wood
Cedar is abundant here, I have had both success and failure with it.
I guess it depends what you are cutting.
There are many qualities of cedar I have some "Old growth" where the rings are so close it is hard to discern the sapwood from the pith. I have also had some wood that was so soft the blade would plow through the pith and bind on the growth rings, smooth lines were hard to achieve.
Some of the best carvings in the world are done by the Northwest Indians, but you will notice thier style of carving has been adapted to work with cedar.
All I can say is, if it is cheap where you are try it and experiment, wear a dust mask.
Check out SSW issue 19 for wood toxicityCAЯL HIRD-RUTTEЯ"proud member of the best scroll sawing forum on the net."Ryobi SC180VS scroll saw EX21
I've used aromatic cedar for scrolling and turning. I've made some beautiful bottle stoppers and ring holders as well as some ornaments. The only problem is if you put a finish on it, you lose the smell.Fred
I use 1/4" aromatic cedar plywood from Wildwood Designs for some of my puzzles, both full-size and Christmas cards. It doesn't hold up over time quite as well, but you're right...it does smell nice. I didn't discover the need for dust protection until I developed a cough while cutting it. A paper mask solved the problem.
Carter
I ve used cedar for a lot of things I make -- bird houses and squirril feeders are great with it - but scrolling I find it tends to break - my large deer pic is in cedar .. but for scrolling I use 1/4 and 1/2 birch ply - to me that works best ..but I do have a dragon statue I am going to do as my next project and since it is a large piece I am going to attempt it in cedar. Hope it works because it will be a gift to my son when he comes home next month ...
I use cedar for the majority of my scrolled ornaments and crosses. As mentioned, it will lose its smell when you put a finish on it. Some finishes are not compatable with the oils in the cedar and won't dry well ~ sorry, but I can't remember which one it was that wouldn't dry when I used it. And it's color will fade overtime - very quickly if left in the light.
Theresa
Reply to FInished Productby KarlBGreat looking! Very impressive work.
Today, 08:51 PM -
Reply to FInished Productby will8989That is beautiful. What are you going to do with it?
Today, 08:12 PM -
by tgiro01Some folks expressed a desire to see this thing once it was completed. This is the bowl I experimented on, with the little Kobalt miter saw.
The downside is that, I used Hickory for most of the bowl. Hickory is a hard brittle wood but, it also has an open grain, which promptly absorbed...-
Today, 06:52 PM -
Reply to The St-Nicolas sheriffHat, ears, and the mustache are some areas you might look at. A mustache that big would surely be bushy. Ears could maybe come forward some.
Nice work. Thanks for sharing with us.-
Today, 05:29 PM -
