We picked up ours from woodcraft 3 weeks ago. It was $329 on sale for $199 about a month ago. We had it shipped to the store to avoid shipping charges. The little I got to use it I was quite impressed. Very quiet can hardly hear it. It is on the table next to my saw. The only down side is it blows into my storage closet. If I face it any other way, it will blow on the furnace, hot water heater or across my saw. But that’s no big deal. I was cutting red heart and I could see on the intake filter side closest to my saw a discoloration. Guess that means it’s doing its job! Very happy with it. We bought a drill press when they first came out with them and it is my, Bruce’s, go to drill press and runs like a charm. Only issue is you need to move belts when you change speed. Bruce does that quite well. I would buy anything from Rikon. In fact, Bruce is talking new lathe again. Yeah, we’ll see.
Rikon air cleaner
Rikon air cleaner
Betty
"Congress needs to realize it is a government of the people, by the people and for the people. Not of the people, by the people and for Congress." - Dr. Benjamin Carson, Pediatric Neurosurgeon, Johns Hopkins HospitalTags: None
I saw that but this was a special 40% off sale, I think.Betty
Reply to Wood lampshadeby RolfReally nice work! I personally prefer a Semi gloss or Satin finish. The only time I may use a gloss finish is on some wood turnings.
Today, 07:44 AM -
Reply to Wood lampshadeby planeurHere is somes of my inserts , in ebony , and I put to reinforce at the back of the bird (chickadee ) a MDF with real wood on each side , total of .096" , because the cuttings was very delicates ! Still have some sanding on a couple of them!
Not finish yet of cutting inserts , I have...-
Today, 07:03 AM -
