Sanding and calibration disk.
  • Sanding and calibration disk.
    A spontaneous purchase bit me in the butt. I bought this disc from woodcraft https://www.woodcraft.com/products/w...mounting-plate with the primary purpose of using it to fine tune my table saw alignment. It is advertised as sanding / calibration disk! I installed it in my table saw and put a dial indicator on it. It has fluctuations of over .015" that would seriously screw up my saw. I sent Woodcraft an e-mail, it will be interesting to see how they respond.
    Woodpeckers just sent an email with something similar for tuning and aligning your table saw, RJ
    Life Begins @ 190 MPH
      Hope they respond faster than Rockler has about an issue we reported in Dec and again in Jan. Not good.
      Betty
        Thank you for sharing. I'd seen that item but didn't get it. Now I'm glad. Will wait and see how they respond to you.
        Linda at www.ArtIngrained.com
          The disk looks like it is powder coated. I don't see how they could do that and get a precise thickness over the entire surface.
            I saw that when I ordered the air cleaner. I mentioned it to Bruce and his comment was I’ll pass. He loves Woodpecker tools and we have quite the collection of them.
            Betty
              I received this response this afternoon.
              "Good afternoon,
              I’m sorry to hear you were upset with the product your ordered, I did process your order for a full refund, and you may keep the item, have a wonderful day and I hope you continue to shop with woodcraft"
              It was a very fair response.
                Thank you for sharing Rolf. Too bad there will be a lot of people less observant than you who will wonder why it doesn't give them the results they want. Anything advertised for calibration should fall under better quality control standards.
                  The good thing is that while I had my saw blade off I cleaned it sprayed Crud cutter on it let it sit then wiped it off with a skotchbright pad. I was surprised that some of the paint washed off also. Strong stuff that crud cutter.
