I purchased a user rbi Hawk 226-m scroll saw that needs the tension spring in the back. The manufacturer is currently out of them. Can anyone give me info as to the size or specs of the spring that's used on this saw?
rbi Hawk scroll saw spring
Hi Bob What is the serial number on the saw that will give me a better idea on what you need.. In the mean time I will measure what is on my Hawk G4 26Rolf
- Likes 1
The manual for this saw is on Bushtons web site
You can find a suitable spring from Mc Master Carr This would probably work.https://www.mcmaster.com/springs/spr...imum-load~7-5/
But It would investigate about the motor first I would see no point in repairing this saw without having the correct motor.
Have you asked Bushton about the motor?Rolf
Thanks for the info about the spring. I do have the manual for the saw that came with it when I bought it. I have contacted Bushton about the motor. I specifically asked, "I may need to replace the AC motor that came with the saw when I purchased it.What motor should I use to replace it?" Their response was, "You would need to replace it with another AC motor, which can be found online. Most aren’t horribly expensive." I've also asked them what the original motor's H.P, voltage, and rpm was, but they won't give me an answer. I can't find this info anywhere on line. If I use an AC motor on the saw I believe I will loose the variable speed functionality that the saw has.
Looking at the manual It does not have the tension quick release on the upper arm. so certainly it is before 2005 as my G4 has the quick release. I am thinking early 90's on the age.
Do a google search hawk scroll saw history there is some discussion on the ssvillage site about the older Hawks.
Bushton bought the Hawk brand in 2009. I am pleasantly surprised that they have supported the older models as much as they have. Especially since some of the parts not manufactured by them are probably no longer available.
Have tried to find a local electric motor repair shop?Last edited by Rolf; Yesterday, 09:12 AM.Rolf
I don't actually have the original motor that came with the saw. From what I can gather it was an 1140 rpm DC motor. The motor that came with the saw when I bought it is an AC 1/3 H.P 1725 rpm 60 HZ. 115 V. I asked Bushton for the specs. on the original motor but they won't, or can't tell me. I don't know why. I'm attaching pictures of the variable speed controller on the saw. I think it can only work with a DC motor. Unfortunately I don't know a lot about AC vs DC motors. I may have to take a crash course on them.Attached Files
Reply to Alex Fox Basket C12by Sandy OaksBetty, I enlarged the pattern by 30% to fit on 10" square stock....Yesterday, 02:20 PM
Reply to Boys at sawmill were busy.by will8989Thanks, Kim. I'll show that to my husband but since he has 2 surgeries coming up I doubt that will be on his to do list. The place we buy wood from air dries the wood for a year, than finishes with kiln drying....
Channel: Wood and Materials
Yesterday, 01:58 PM -
by will8989Received email from Woodcraft, the Rikon1/4 HP 3 speed air filter, reg $329.99 is on sale for $199.99. Remote controls, timer, 5 year warranty, etc.. Called store, have them on backorder but one is mine as I paid for it today. Will call me when it comes in. Warranty sold me. It is in their sale circular...
Yesterday, 01:54 PM -
Reply to Boys at sawmill were busy.by Kim Stonewill8989, We made a drying kiln out of a plan we saw on youtube. We took a 6-Tier Commercial Grade Heavy Duty Steel Wire Shelving Unit that we got at lowes, wrapped it in 1 inch foam insulation board and put two heat bulbs in the bottom, we have holes at the top and bottom to let the moisture out. We...
Yesterday, 01:49 PM -
Reply to Alex Fox Basket C12by will8989I made that awhile back out of 1/4 cherry. Came out great but drove me crazy gluing up. Of course, that was a short ride!!...Yesterday, 01:41 PM
